Can't upgrade past 1.40.2.8395
Server Version#: 1.40.2.8395
Player Version#: 4.125.1
OS: Ubuntu 20.04.6 LTS
I haven’t been able to upgrade past version 1.40.2.8395, I have tried all the following
1.40.3.8555
1.40.4.8679
1.40.5.8854
I can revert to 1.40.2.8395 or any previous version and it works just fine. I have also ran ChuckPA PlexDBReapir. When trying to upgrade it gets stuck into, “Plex Media Server is currently running database migrations.” and I had times where the plex service would stop or be stuck in the running database migration. When tailing the log I see
Aug 15, 2024 09:25:34.237 [140280446126736] INFO - Running migrations. (EPG 0)
Aug 15, 2024 09:25:34.237 [140280446126736] INFO - Analyzing database.
Aug 15, 2024 09:25:34.368 [140280446126736] INFO - Vacuuming database.
Aug 15, 2024 09:25:35.847 [140280438799160] WARN - Crash: Crash reporting disabled
Aug 15, 2024 09:26:00.597 [140280446126736] ERROR - SQLITE3:0x80000001, 13, statement aborts at 7: [INSERT INTO vacuum_db.'blobs' SELECT*FROM"main".'blobs'] database or disk is full
Aug 15, 2024 09:26:01.442 [140280446126736] ERROR - SQLITE3:0x80000001, 13, statement aborts at 1: [VACUUM] database or disk is full
Aug 15, 2024 09:26:01.444 [140280446126736] ERROR - Exception thrown during migrations, aborting: sqlite3_statement_backend::loadOne: database or disk is full
Aug 15, 2024 09:26:01.444 [140280446126736] ERROR - Database corruption: sqlite3_statement_backend::loadOne: database or disk is full
Aug 15, 2024 09:26:01.444 [140280446126736] ERROR - Error: Unable to set up server: sqlite3_statement_backend::loadOne: database or disk is full (N4soci10soci_errorE)
Logs.zip (963.4 KB)
@media_plex_master
Look at what it’s telling you.
The disk/partition where PMS is being stored – IS FULL.
The default location is /var/lib , which is the / filesystem
When you type df -h, it will show you.
You’ll see it’s full.
This is probably the time for you to move your PMS to a different partition or disk.
Aug 15, 2024 11:22:22.388 [139837734210192] ERROR - SQLITE3:0x80000001, 13, statement aborts at 7: [INSERT INTO vacuum_db.'blobs' SELECT*FROM"main".'blobs'] database or disk is full
Aug 15, 2024 11:22:23.250 [139837734210192] ERROR - SQLITE3:0x80000001, 13, statement aborts at 1: [VACUUM] database or disk is full
Aug 15, 2024 11:22:23.252 [139837734210192] ERROR - Exception thrown during migrations, aborting: sqlite3_statement_backend::loadOne: database or disk is full
Aug 15, 2024 11:22:23.252 [139837734210192] ERROR - Database corruption: sqlite3_statement_backend::loadOne: database or disk is full
Aug 15, 2024 11:22:23.252 [139837734210192] ERROR - Error: Unable to set up server: sqlite3_statement_backend::loadOne: database or disk is full (N4soci10soci_errorE)
I’ll help you do that. It’s very easy on Linux.
I have plex on /dev/sdb1 (/plex) unless I’m missing something.
Filesystem                                                            Size  Used Avail Use% Mounted on
udev        35G     0   35G   0% /dev
tmpfs        6.9G  1.4M  6.9G   1% /run
/dev/mapper/ubuntu--vg-ubuntu--lv                                      20G   16G  2.7G  86% /
tmpfs        35G  4.0K   35G   1% /dev/shm
tmpfs        5.0M     0  5.0M   0% /run/lock
tmpfs        35G     0   35G   0% /sys/fs/cgroup
/dev/sda2                                                             974M  211M  696M  24% /boot
tmpfs        40G     0   40G   0% /media/ramdisk
/dev/sdb1                                                            1007G  459G  498G  48% /plex
/dev/loop2                                                             64M   64M     0 100% /snap/core20/2318
/dev/loop1                                                             56M   56M     0 100% /snap/core18/2829
/dev/loop0                                                             56M   56M     0 100% /snap/core18/2823
/dev/loop3                                                             92M   92M     0 100% /snap/lxd/24061
/dev/loop4                                                             92M   92M     0 100% /snap/lxd/29619
/dev/loop5                                                             64M   64M     0 100% /snap/core20/2264
/dev/loop6                                                             39M   39M     0 100% /snap/snapd/21465
/dev/loop7                                                             39M   39M     0 100% /snap/snapd/21759
tmpfs        6.9G     0  6.9G   0% /run/user/1000
under /var/lib
lrwxrwxrwx  1 root      root        21 Nov 23  2020 plexmediaserver -> /plex/plexmediaserver
Edit: Increased the /dev/mapper/ubuntu–vg-ubuntu–lv, which plex is now working, I ignored the disk is full msg because I didn’t think that would matter since plex lives under a 1TB mount /dev/sdb1 /plex.
Don’t use symlinks.
Use the systemd override.
This means PMS is looking at the right places and not putting things into /var/lib to cause problems as is being reported.
/var/lib/plexmediaserver is Plex’s HOME directory.
If that shows full, it will get cranky
Also do check the free space available. Something is out of space.
Supplemental:
This is my configuration
[chuck@lizum ~.2051]$ cat /etc/systemd/system/plexmediaserver.service.d/override.conf
[Service]
Environment="PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/usb/plex"
User=chuck
Group=chuck
[chuck@lizum ~.2052]$
/var/lib/plexmediaserver still exists, is owned by my username, but is empty.
/usb/plex is really a 2TB SSD now. No longer a HDD
Thanks, yeah i’ll just make a override.conf, I forgot about the location of /usr/lib/plexmediaserver. But either way seems resolved once I expanded /dev/mapper/ubuntu–vg-ubuntu–lv.
/usr/lib/plexmediaserver is for the software. It is managed by the package manager.
/var/lib/plexmediaserver is where plex’s $HOME is.
We only need concern ourselves about this directory
Yeah, what I just cant figure out why it was saying disk full when I had symlink to /dev/sdb1, for /usr/lib/plexmediaserver. I would of thought 2GB left would be plenty for /dev/mapper/ubuntu–vg-ubuntu–lv, since plex data isn’t technically running on main drive but the secondary drive with over 500GB of space. But yeah once i added additional space to /dev/mapper/ubuntu–vg-ubuntu–lv it worked instantly.
Either way I created an override.conf instead of a symlink.
The symlink was the problem.
df will not follow the symlink to tell you the space free at the destination without using the trailing slash. PMS does not add trailing / to pathnames because it already knows it’s a DIRECTORY.
