Hi there,
Quick breakdown. I’m running Plex on a Mac with all of my files on two external drives. Movies are sorted into folder by genre and I add movies to Plex by creating a Library with the genre name and then adding the specific genre folder to that library.
I am converting all of my files to MP4 using the following steps.
- I search the genre directory for any existing MP4 files and move them to a TEMP directory so they are not transcoded as they’re already in MP4 format.
- I do a full refresh of the Genre library so only the files that need to be transcoded are listed.
- I transcode all files in the Library to MP4 and then place the newly created MP4 file in the movie folder and delete the old movie file.
- I put all of the files that were stored in the TEMP directory back into their movie folders and I’m done. Everything in that Library should now be MP4.
- Finally I do a refresh of the Library to reflect the new files.
For some reason Plex is taking all of these files and putting them in the trash and I have no idea why. I had thought that it was due to one of my drives being NTFS so I formatted it to exFat. I had also read somewhere that moving files between drives when you’re using a USB hub can cause problems so I plugged the drives straight into the iMac but it still happens.
The only thing I can think of that might cause a problem is that I’m running Windows 7 under Parallels and I use a program on their to scan for empty directories to make sure I’ve put everything back into the right place. and I haven’t overlooked any movies. Finder is garbage for trying to do any type of search or file management so that part is done in Windows 7 VM.
Sorry for the long post but I wanted to offer up all of the information I can. If anyone else has seen this before and has a solution I’d much appreciate it.
