Plex deskop Language Changed from english to dutch
On all my pc’s with the settings on english ?
Lastest desktop version
Can yo please take a screen shot of where it is showing as dutch and the language setting.
All settings are in dutch and most things on the menu’s only some remain in english .
Happend overnight and there was no new version
Problem remains after reinstall.
Do not have the issue on android app or Web . Only in the desktop app
You are looking in the wrong place for the language setting.
Your second-to-last screenshot is showing a generic language setting that is bound to your user account (and is probably no longer used in any of the currently supported clients).
The language setting for the app interface of the Plex web app and Plex for Desktop is to be found under
Settings - Plex Web/[Plex for Windows/Mac/Linux] - General
In your last screen shot you want the Algemeen section which is the General settings @OttoKerner is referring to.
the general under Plex for Windows. Not the one under your server name, You are trying to change the language of Plex for Windows.
You are in the wrong section.
Don’t go into the settings for the server.
Go upwards in the side panel, to the other “General”
Found it thanks a lot!!!
Still don’t understand how it changed overnight.
But it works now !
