Server Version#:
Player Version#: 1.95.2
I’m new to Linux and installed Mint 21.3 Cinnamon. I want to run this machine only as a Home Theater machine done from my parts of my old computer.
I cannot start Plex and when I start it as a command I get the following error.
F: No installations directory in /etc/flatpak/installations.d. Skipping
F: Opening system flatpak installation at path /var/lib/flatpak
F: Opening user flatpak installation at path /home/home/.local/share/flatpak
F: Skipping parental controls check for app/tv.plex.PlexDesktop/x86_64/stable since parental controls are disabled globally
F: /home/home/.local/share/flatpak/runtime/org.freedesktop.Platform/x86_64/23.08/1aeabe05e0b2e73715b44957ce19943117a0f4a9201c3612fe095da2333fe77b/files/lib32 does not exist
F: Cleaning up unused container id 2513791270
F: Cleaning up per-app-ID state for tv.plex.PlexDesktop
F: Allocated instance id 1936600851
F: Add defaults in dir /tv/plex/PlexDesktop/
F: Add locks in dir /tv/plex/PlexDesktop/
F: Allowing homedir access
F: Allowing x11 access
F: Allowing pulseaudio access
F: Running ‘bwrap --args 41 xdg-dbus-proxy --args=43’
F: Running ‘bwrap --args 41 Plex’
*** stack smashing detected ***: terminated
/app/bin/Plex: line 48: 5 Aborted (core dumped) “$BASE_DIR”/bin/plex-bin “$@”
ChatGPT says that this error: *** stack smashing detected ***: terminated
/app/bin/Plex: line 48: 5 Aborted (core dumped) “$BASE_DIR”/bin/plex-bin “$@” has something to do with memory buffer, so are my parts not compatible?
Thanks and regards.
