Plex do not play MKV file
Server Version#: Debian 10
Player Version#: PlexMediaServer latest
Hello, my weaner plex can’t read mkv and avi files, it can only read mp4 files. According to the logs, this is due to encoding problems.
I tested with several mkv and avi
Logs of server:
Plex Media Server.1.log (1.6 MB)
Plex Media Server.2.log (862.7 KB)
Plex Media Server.3.log (1.7 MB)
For future reference, Please turn VERBOSE logging OFF. It outputs far more data than we need (it logs every packet) which makes diagnosing much harder.
The errors I’m seeing look like the Transcoder is using Dolby audio and converting to AAC.
Where is the transcoder’s temporary directory ?
I ask because if the transcoder cannot set up notification for the temp directory then the Easy Access Encoder (which converts Dolby audio) will fail.
What type of audio is in the MKV you played in the example logs you provided?
