Plex Employee to Reset Server Certificate? "API rate limit exceeded" error
Stop PMS
Go into the “Cache” directory.
Delete cert-v2.p12
Now start PMS.
If you have your own certificate, which this error is indicative of.
[quote="CFarence, post:465, topic:715763"]
Apr 17, 2023 02:41:06.135 [0x7fba7b4f5b38] ERROR - [CERT] PKCS12_parse failed: error:0308010C:digital envelope routines::unsupported
[/quote]
I’m having this issue as well.
Apr 17, 2023 14:34:51.262 [0x806a14a00] Error — [CERT] PKCS12_parse failed: error:0308010C:digital envelope routines::unsupported
Apr 17, 2023 14:34:51.262 [0x806a14a00] Error — [CERT] Found a certificate, but couldn’t install it.
Apr 17, 2023 14:34:51.263 [0x806a14a00] Error — [CERT] PKCS12_parse failed: error:0308010C:digital envelope routines::unsupported
Apr 17, 2023 14:34:52.029 [0x806a15100] Warning — [EventSourceClient/pubsub/45.118.132.58:443] PubSub: Received notifyConnectivity event with incorrect async identifier (, expected )
Apr 17, 2023 14:34:52.029 [0x806a14a00] Error — [CERT] CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
@ChrisMNZ
Do you have your own cert ?
No I don’t - just local install.
ALL:
Stand by please. Calling in the Calvary.
:slight_smile:
Hi @ChuckPa I’m experiencing this issue as well, I am not running my own cert. This started right after a server update (Running Version 1.32.0.6918-6f393eda1 on Mac OS).
Am I experiencing the same issues as others, and would you be able to help?
ALL:
Please do the following:
  1. Restart PMS
  2. Give it a minute to get all confused.
  3. Stop
  4. Make a ZIP of the 'Logs" directory
  5. Upload that ZIP file here.
Thanks for the help.
Plex Media Server.zip (2.6 MB)
@brc4ever
Got your logs… thanks.
I cleared the ‘429’ but it’s not propagated to you yet/
Plex.tv is “out to lunch”.
It’s “stuck” generating your certificate.
I’m waiting for someone to respond.
Much appreciated @ChuckPa …I’ll stand by.
Redacted by Moderator
Thanks. Got it
I don’t remember setting up a custom certificate, I’m assuming Preferences.xml would contain the settings related to custom certificates as it does contain the rest and mine doesn’t have anything related to custom certificates, though I can’t get back into the server to check the UI.
Just a heads up getting the same issue. I have it installed on TrueNAS and rolling back didn’t fix the issue.
@BILLTHETURNIP
Can I get your logs please ?
Hopefully more logs help:
Pretty standard docker install. Getting image from plexinc/pms-docker. Tried turning PMS off for about 5 min, repulled images and it loops with what others have posted with:
ERROR - [CERT] Found a certificate, but couldn’t install it.
WARN - Crash: Crash reporting disabled
ERROR - [CERT] CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
PlexLogs4.16.zip (10.1 MB)
Tried deleting the cert-v2.p12 the errors in the logs go away but the server isnt accessible publicly. Locally does still work.
PlexLogs4.16NoCert.zip (10.1 MB)
@Zyrax1
Thanks.
I have help now and they’re looking at it.
Just gave them your logs
@Zyrax1
Turn on DEBUG Logging – SAVE – RESTART
Gotta have debug loggin
I think this should be debug on
Can you reset my cert.
BringerOD.
We’re trying to solve a problem
Please make sure DEBUG Logging is enabled.
Restart PMS
Grab the logs ZIP file and attach.
We have a cert issue upstream
