Server Version: 1.15.4.993
Player Version: 7.14.1.9954
After recent update on Fire-TV client-side app, Plex started transcoding the video for subtitles even for srt formats. I double checked the burn subtitles settings in fire tv and tried both automatic and only burn image subs.
An example case for a video with mediainfo result:
Format : Matroska
Format version : Version 4
File size : 4.32 GiB
Duration : 1 h 21 min
Overall bit rate : 7 553 kb/s
Encoded date : UTC 2019-04-29 01:05:53
Writing application : mkvmerge v33.1.0 (‘Primrose’) 64-bit
Writing library : libebml v1.3.7 + libmatroska v1.5.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Constant
Bit rate : 6 911 kb/s
Nominal bit rate : 10 000 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.139
Stream size : 3.95 GiB (91%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : A_EAC3
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : 2 ms
Stream size : 375 MiB (8%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 19 min
Bit rate : 8 b/s
Count of elements : 203
Stream size : 4.82 KiB (0%)
Language : English
Default : No
Forced : No
without subs:
with subs:
As you can see, it starts transcoding when I add the SRT subtitles. It happens every video which was previously working fine for direct play.
UPDATE: It seems, it only occurs in some videos. I found a video with soft subtitles are working as expected. Here’s mediainfo of that file;
Format : Matroska
File size : 2.28 GiB
Duration : 1 h 48 min
Overall bit rate : 3 004 kb/s
Encoded date : UTC 2016-01-23 19:04:32
Writing application : mkvmerge v7.7.0 (‘Six Voices’) 64bit built on Mar 1 2015 01:50:05
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Video
Format : AVC
Format settings : CABAC / 8 Ref Frames
Format settings, ReFrames : 8 frames
Bit rate : 2 560 kb/s
Width : 1 280 pixels
Height : 720 pixels
Frame rate mode : Variable
Frame rate : 23.976 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.116
Stream size : 1.94 GiB (85%)
Writing library : x264 core 130 r2273 b3065e6
Encoding settings : cabac=1 / ref=8 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.25 / mixed_ref=0 / me_range=48 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=0 / chroma_qp_offset=-4 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=2pass / mbtree=1 / bitrate=2560 / ratetol=1.0 / qcomp=0.00 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=20000 / vbv_bufsize=25000 / nal_hrd=none / ip_ratio=1.10 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate : 448 kb/s
Bit depth : 16 bits
Stream size : 348 MiB (15%)
Title : Surround
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Duration : 1 h 42 min
Bit rate : 50 b/s
Count of elements : 1074
Stream size : 37.7 KiB (0%)
Language : English
Default : Yes
Forced : No
