Plex for iOS forgets resolution settings
Server Version#: 1.42.2.10156
Player Version#: 2025.26.0 (1279)
Honestly I don’t know if this is a bug or a feature but I want to post it anyway. :wink:
Plex for iOS does not keep the settings for the resolution. It’s pretty easy to reproduce (I’ve used a Phone 13 mini on iOS 18.7.1 (22H31).
  • Go to ‘user icon’>settings>video and audio>mobile network quality and select another resolution
  • Logout and back in again
  • Your settings are toast and you have to set it up again.
    Logs attached
plex-log-2025-10-04T23_09_18.002Z.zip (426.4 KB)
My item is called Cellular Quality. I’ll guess you mean that setting.
I changed mine from 720p 2 Mbps to 1080p 8 Mpbs.
How do you logout? Do you mean Switch Profile?
Do you mean quit the app by swiping it upward then starting it again?
Exactly. I use german as main language so I didn’t knew how it is translated. :wink:
No, I don’t.
Click and then Settings>User account> log out. (Optional: kill the app by swiping up and open it again) and re-login.
And… your settings are gone. :pensive_face:
