Plex default video quality
Hello,
It seems everytime I change from device or I think even plex app updates the video quality always lowers to 2mbps.
I have been like this during the last 6 months waiting for the team to solve this issue. Is anyone at any point experiencing the same? Or do we know if plex team is trying to solve this issue?
Kind regards
Hello,
I am doing that all time and when I swap between platforms I arrive to the same:
Kind regards
Hello,
I have been doing a bit of research and it seems like the setting of the user are saved no where, which means that everytime a user logs into a different computer, he needs to create new config, also if user logs out in PMP and logs so that another user can log in and then relogs in again, the settings will not be neither saves. Do not really know why this is not solved and all user config is synced between devices and stored into the account data as password and other settings of the account.
Kind regards
Hello,
Any feedback from Plex team?
Kind regards
You have to change this for each client you use and after the change, make sure you hit the SAVE button at the bottom of the quality setting. I switched to the other home user (wife) and made a change there as well then went back to mine and it kept.
Hello,
I was not for me, thats what I am saying.
Kind regards
