Editor doesn’t appear in some of my post?
This appears to be a very old post which was imported from the old (pre-Vanilla) Plex forums in HTML format.
The formatting toolbar doesn’t work for those posts.
So there’s no way of resetting it?
I can’t use markdown in it at all?
Not that I know of. You may have to use HTML instead.
Or create a completely new thread. Do ping me if you want the old one locked.
I have successfully converted a post from old school IPB to Markdown
Did you have to completely remove the html tags and replace them with markdown?
The HTML can stay. But I removed it and used markup so that it is easier to read for future edits:
