one thing: If i wanna play a 4K movie on Plex (Direct Play) it works fine but as soon as i change the resolution to 1080p or something like that my cpu jumps to 100% (yes i know because of the transcoding…) But is there another way like gpu transcoding that works or do i need to buy a super high end 50k cpu xD
Yes, you can enable GPU “Hardware” assisted transcode if you have a supported GPU. TeknoJunky didn’t make it to the very bottom of the link they posted. So you don’t need a 50k cpu, only a 40k GPU.
My new system with a RTX 2070 barely touches the CPU for a single UHD blu-ray to 1080 transcode but if I disable GPU assist it works all my 3950x’s cores pretty good (with the MAKE MY CPU HURT/max quality setting on).
Ah, yes. I didn’t notice the lack of Plex Pass on the name. But note his question is specifically about GPU transcoding as he asks if there “is there another way like gpu transcoding”.
So I would revise the answer to be: “Yes, you can enable GPU transcoding but it requires Plex Pass subscription which is cheaper than a 50k cpu.”.
Ok well, I took his question “is there another way like gpu transcoding” to mean “is there another way like gpu transcoding (that isn’t gpu transcoding)".
But I can now also see it could be interpreted as “is there another way? like gpu transcoding?”
either way, grammar matters, and without plexpass gpu is irrelevant.
so i bought plex pass. my cpu (i7 4790) supports quick video sync. i also have a quadro k2200 graphics card and i also activated “Use hardware-accelerated video encoding” but it won’t work. either with x264 x265 and so on
