Server Version#: 1.16.2.1297
Player Version#: Web Client Version 3.99.2
Windows 10 with Nvidia P400
I’m not sure what could be the problem here. I’ve been able to recreate this and it seems to be an issue with being logged into the system. I have auto-login turned on. I have a monitor plugged into the P400, i’ve tried it with a dongle as well to no avail.
If anyone has any tips/tricks or experience with fixing this that would be appreciated. It is more of an annoyance since I have to login to the RDP session then just close RDP. So if i were not home it would not work well as I would have to somehow remote into the system just to have HW decoding working =(
Are you using Microsoft’s Remote Desktop Client? If so, don’t use it. It creates a graphics adapter which seems to confuse Plex.
(Had the same problem)
I experienced the same behavior. When I was logged in through Microsoft Remote Desktop hardware transcoding worked. When I exited it, hardware transcoding stopped working after a short while. But then I used Chrome Remote Desktop and because of that the graphics adapter RDP enables was deactivated. Then hardware transcoding worked as it should.
I see.
I meant hardware decoding and encoding when I said hardware transcoding.
For me it was the reverse scenario:
Fresh reboot and both worked for a while.
With RDP enabled decoding stopped working and encoding worked.
As soon as I disabled the graphics adapter RDP enabled, both worked reliable.
So I thought you were in the same situation.
Do you have any other GPUs built into your PC? Like an integrated GPU?
