Plex HW (GPU - Nvidia) Transcoding is not working
Server Version#:
My plex HW (GPU) transcoding was working fine until I changed the GPU. After replacing the gpu I have done the changes to Nvidia GPU in NVIDIA_VISIBLE_DEVICES. Still its the hw transcoding not working? Please help me.
Plex Logs:
text error warn system array login
chown: missing operand after ‘plex:plex’
Try ‘chown --help’ for more information.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
Connection to 172.104.62.76 closed by remote host.
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec … or kill -l [sigspec]
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
Creating pref shell
Attempting to obtain server token from claim token
Plex Media Server first run setup complete
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing…
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
Critical: libusb_init failed
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
Stopping Plex Media Server.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
