i have only one user and no pin for this account
here log
thanks
Sortie standard/erreur : Traceback (most recent call last): File "/volume1/scripts/plex_notify.py", line 200, in <module> plex_account_token File "/volume1/scripts/plex_notify.py", line 170, in url_open return urllib.request.urlopen(req, context=ctx) File "/volume1/@appstore/py3k/usr/local/lib/python3.5/urllib/request.py", line 162, in urlopen return opener.open(url, data, timeout) File "/volume1/@appstore/py3k/usr/local/lib/python3.5/urllib/request.py", line 471, in open response = meth(req, response) File "/volume1/@appstore/py3k/usr/local/lib/python3.5/urllib/request.py", line 581, in http_response 'http', request, response, code, msg, hdrs) File "/volume1/@appstore/py3k/usr/local/lib/python3.5/urllib/request.py", line 509, in error return self._call_chain(*args) File "/volume1/@appstore/py3k/usr/local/lib/python3.5/urllib/request.py", line 443, in _call_chain result = func(*args) File "/volume1/@appstore/py3k/usr/local/lib/python3.5/urllib/request.py", line 589, in http_error_default raise HTTPError(req.full_url, code, msg, hdrs, fp) urllib.error.HTTPError: HTTP Error 401: Unauthorized
@kaizo33 said:
since update 1.1.0, it doesn’t work
I’m not sure why you’re getting that error now with only one user and no PIN, but did you try setting the plex_account_token variable in the version 1.3 script in my first post? There are instructions in the “troubleshooting” section that explain how to set that variable.
P.S. I’m using this script with PMS v1.1.0.2611 and it’s working fine here.
thanks i have put token but i have another error
i have put token and it work fine
and for another isuue, i have renamed a library and forgot change on script.
So, I wrote a script to automate that (borrowed heavily from here).
Let me know if you find this useful!
Oh man… You don’t know how much you’ve helped me. Thanks so much! I’m using this to be able to run Plex as a virtual computer with a cifs mount. And this solves everything. Thanks!
Firstly, thank you for the great script. I have been using version 1.3 for a while without any problem but recently it stopped working. I updated to version 1.4, initially by just copying over the modified variables (didn’t work), then by recreating the file entirely. However, whatever I try I get the same syntax error message in terminal when I run the program using ‘python plex-inotify.py’:
File “plex-inotify.py”, line 222
print(err, file=sys.stderr)
SyntaxError: invalid syntax
Do you know why this is happening? I have tried deleting the last command but then there is another error instead:
File “plex-inotify.py”, line 57, in
import urllib.request
ImportError: No module named request
If, using the complete script, I try ‘sudo python3 flex-inotify.py’ I get:
File “plex-inotify.py”, line 51, in
import pyinotify
ImportError: No module named ‘pyinotify’
The log file has ben created but is empty. I have deleted and reinstalled Python and the extensions (Python 3.5.1-0104 and Python Module 0108 running on Synology 713+ NAS) but am not sure where to go from here, I miss the automatic updates!
In this case it’s because you’re running the script with Python 2, which isn’t supported.
import pyinotify
In this case you’re running the script with Python 3, which is good, but you don’t have the pyinotify module installed. If you look at my first post, you’ll see I’ve written instructions on how to install the pyinotify module, which the script depends on.
Thanks for the quick reply, I have been away and have just looked at it again today. I had followed the installation instructions again, but each time I run easy_install I get this message:
Searching for pyinotify
Best match: pyinotify 0.9.6
Processing pyinotify-0.9.6-py2.7.egg
pyinotify 0.9.6 is already the active version in easy-install.pth
Using /usr/lib/python2.7/site-packages/pyinotify-0.9.6-py2.7.egg
Processing dependencies for pyinotify
Finished processing dependencies for pyinotify
I was also getting errors - command not found - when I tried pip or pip3 to install pyinotify. Then I stupidly deleted the python2.7 folder and nothing works! pip and pip3are still not found but I cannot seem to install pip successfully. Probably going to give up.
I’m woefully out of my league here. I need this script (not auto-updating from a NAS is horrible) as I am just now planning to move from 2 8TB hard drives to a NAS.
I have installed PlexPy (super rad, in case anyone cared), but the instructions were incredibly detailed for me to follow. Here, they’re a little advanced. Are there any options for someone not very familiar with Terminal (but enough to follow directions) on a Mac using a Synology NAS on DSM 6.0.2?
Honestly, even trying to get the link above to start a Plex library scan would be fine. I could set that on my Android on the home screen but I get 401 Unauthorized as I have Home set up with a PIN. I tried adding my token at the end, but I then get a 404.
I have the script working finally, but I don’t know what my local paths are. I’ve tried every combination I can think of for the mounted drives, and it’s saying not found. What does a local path look like as an example?
before : the local path
after : name of the library in Plex
you can figure out the path if you right click on a library and go to edit. there you specify the location of the files for your library and in my case it says /volume1/photo (it’s the path on my Synology)
Just copy the path
