If Plex can see /dev/dri/renderD128 but still falls back to CPU transcoding on an Intel Arrow Lake GPU, this workaround may help.
I found two separate causes:
Plex’s bundled Intel media driver was too old for the Arrow Lake GPU.
The Plex server process lost access to the render-device group during startup, even though manual VAAPI tests inside the container worked.
The fix uses a newer Intel media driver built for Plex’s bundled musl environment, mounts it persistently in the container, and gives the actual Plex process access to the render-device GID.
I confirmed the result with real Plex playback: 4K HEVC hardware decoding, VAAPI zero-copy processing, and H.264 hardware encoding all worked. Plex displayed (hw) and CPU usage dropped substantially.
Tested configuration:
Intel Arrow Lake-P GPU (
8086:7d51) -
Proxmox VE 9.2.18 → unprivileged Debian 13 LXC → Docker Compose
Official
plexinc/pms-dockerimage -
Plex Media Server
1.43.4.10903-e5521bd8c -
Intel media-driver
26.1.6 -
VAAPI ABI
1.22
The repository includes the full Docker Compose setup, checksummed prebuilt x86-64 binaries, a pinned-source Docker build, verification scripts, and rollback steps:
Plex Arrow Lake hardware-transcoding guide
This is an unofficial community workaround. Check the compatibility notes and back up your Plex configuration before applying it. The source-build path is available if you prefer not to use prebuilt binaries.
