@DracIsBack said:
All of my TV shows are separated into different folders where the structure is TV Shows > Simpsons > Season 1 > Episode 1, 2, 3 etc
Simply put - that won’t work.
https://support.plex.tv/hc/en-us/categories/200028098-Media-Preparation
https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Season-Based-TV-Shows
If TV Shows are not put in specific structures with very specific file names they won’t work and this isn’t a negotiation:
Step one is to find out the EXACT Show name used at TVDB: https://www.thetvdb.com/
Then follow the instructions:
A TV Show Library/
…The Simpsons/
…Season 01/
…The Simpsons - S01E01.xxx
…The Simpsons - S01E02 - Episode Name Optional.xxx
Do that and all is well. Do anything else and expect random or immediate failures, unexpected, unpredictable behavior and zero reliability.
FileBot (link in my signature) can handle that naming and structuring for you automatically or manually in seconds.
What FileBot can’t do is remove possible embedded metadata in the Title Field of MP4/M4V files. Plex will read this info and prefer it over a perfect file name/structure (you don’t have any of those yet), but you can combat that situation by moving Local Media Assets to the bottom of every agent list you can find. All tabs in TV Show and Movies here:
https://support.plex.tv/hc/en-us/articles/200241558-Agents
Just drag LMA to the bottom of the list and drop it. If you do have embedded metadata this will cure the issue, if you don’t it won’t matter. LMA will do what it has to from the bottom.
Renaming/restructuring is best performed OUTSIDE the library and you’ll need to write a new bundle for the show so The Plex Dance® was invented:
The Plex Dance®:
- remove show/movie from library
- update library
- empty trash
- clean bundles
https://support.plex.tv/hc/en-us/articles/200392106-Library-Actions <— update library, empty trash, clean bundles
- bring names and structures into compliance/Move Local Media Assets/etc
- replace corrected show/movie into library
- update library
All Steps. In Order. No Shortcuts.
When the show has a successor - later version - reboot - upgrade - etc:
Doctor Who (1963) <— The Classic First Episodes
You have to go to TVDB and search out the (YEAR) of first airing. Then:
A TV Show Library/
…Doctor Who (1963)/
…Season 01/
…Doctor Who (1963) - S01E01. xxx
Start Fixing. Start Dancing. If you still have trouble - Log Files:
https://support.plex.tv/hc/en-us/articles/200250417-Plex-Media-Server-Log-Files
Drag zip file to message window and drop it.
