Plex Keeps Crashing Synology NAS Drive
I have been trying to resolve this for over a week, but need some help. My ds718+ was crashing on a daily basis. I opened a ticket with Synology, who told me that Plex was causing the crashes and to try installing the public version as appose to the Plex Pass release. I successfully uninstalled Plex, the reinstalled v1.15.4.993. After this, NAS has gone from crashing daily to just randomly becoming hung (cannot login to it or access Plex). The only change I have made recently is added a WD external hard drive with a lot (about 5 TB) of files. Bellow are my specs:
DS718+ NAS
DSM 6.2.2-24922
RAM: 2 GB
CPU: INTEL Celeron J3455
WD 8 TB External Drive
PMS Version#: 1.15.4.993
I’m uploading the logs as well. Any help is greatly appreciated!
Plex Media Server Logs_2019-05-04_07-55-59.zip (3.3 MB)
Thanks so much for the quick reply. I give this a try and update this post if needed!
To add to the feedback you had from @trumpy81
There appear to be database corruptions and scanner crashes due to the corruptions
So you will need to go through repair / restore anyway
May 02, 2019 16:07:39.575 [0x7f8f337af700] DEBUG - Updating metadata item (save) (Vampire Hunter D: Bloodlust) with ID 468
May 02, 2019 16:07:39.576 [0x7f8f337af700] ERROR - SQLITE3:(nil), 11, database corruption at line 64757 of [bf8c1b2b7a]
May 02, 2019 16:07:39.576 [0x7f8f337af700] ERROR - SQLITE3:(nil), 11, database corruption at line 64798 of [bf8c1b2b7a]
May 02, 2019 16:07:39.576 [0x7f8f337af700] ERROR - SQLITE3:(nil), 11, statement aborts at 217: [update metadata_items set library_section_id=:metadata_items_library_section_id,parent_id=:metadata_items_parent_id,metadata_type=:metadata_items_metadata_type,guid=:metadata_items_gu
May 02, 2019 16:07:39.576 [0x7f8f337af700] ERROR - Exception inside transaction (inside=1) (../Library/MetadataItem.cpp:958): sqlite3_statement_backend::loadOne: database disk image is malformed
May 02, 2019 16:07:39.577 [0x7f8f337af700] ERROR - Exception in worker thread: sqlite3_statement_backend::loadOne: database disk image is malformed
https://support.plex.tv/articles/201100678-repair-a-corrupt-database/
https://support.plex.tv/articles/202485658-restore-a-database-backed-up-via-scheduled-tasks/
