Plex Live TV errors Unable to find title for item of type 5 and [Transcoder] [mpeg2video @ 0x16e1580] Invalid frame dimensions 0x0
Hallo,
During playback on most of all live tv streaming I receive many errors like [Transcoder] [mpeg2video @ 0x16e1580] Invalid frame dimensions 0x0 and Unable to find title for item of type.
Any suggestions?
This is the log file during a streaming playback:
Feb 18, 2020 13:42:59.184 [0x7fbb031ea700] INFO - Plex Media Server v1.18.6.2368-97add474d - Synology DS218+ x86_64 - build: linux-x86_64 synology - GMT 01:00
Feb 18, 2020 13:42:59.186 [0x7fbb031ea700] INFO - Linux version: DSM 6.2.2.24922-4, language: en-US
Feb 18, 2020 13:42:59.186 [0x7fbb031ea700] INFO - Processor Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
Feb 18, 2020 13:42:59.186 [0x7fbb031ea700] INFO - /var/packages/Plex Media Server/target/Plex Media Server
Feb 18, 2020 13:42:59.930 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.933 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.937 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.940 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.943 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.946 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.950 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.953 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.956 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.960 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.963 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.966 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.970 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.973 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.976 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.979 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.983 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.986 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:42:59.989 [0x7fbb0d82c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 18, 2020 13:43:00.015 [0x7fbb0d82c740] INFO - OCSP: Successfully retrieved response from cache.
Feb 18, 2020 13:43:04.857 [0x7fbb008ec700] INFO - Refreshing paths watched by LibraryUpdateManager
Feb 18, 2020 13:43:05.339 [0x7fbae2e6b700] ERROR - getaddrinfo(192-168-1-4.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -2
Feb 18, 2020 13:43:05.344 [0x7fbae3a23700] INFO - SQLITE3:(nil), 283, recovered 397 frames from WAL file /volume1/Plex/Library/Application Support/Plex Media Server/Plug-in Support/Databases/tv.plex.providers.epg.cloud-32bd6ccd-5996-4bd3-b31a-68c2f9155294.db-wal
Feb 18, 2020 13:43:05.791 [0x7fbb00310700] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Feb 18, 2020 13:43:05.792 [0x7fbae1fc5700] WARN - Sync: local sync directory "/volume1/Plex/Library/Application Support/Plex Media Server/Cache/Transcode/Sync+" does not exist
Feb 18, 2020 13:43:06.314 [0x7fbb020ab700] ERROR - getaddrinfo(192-168-1-4.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -2
Feb 18, 2020 13:43:09.675 [0x7fbae25a1700] INFO - AutoUpdate: no updates available
Feb 18, 2020 13:43:19.469 [0x7fbae2b7d700] INFO - AutoUpdate: no updates available
Feb 18, 2020 13:43:24.547 [0x7fbae2b7d700] INFO - AutoUpdate: no updates available
Feb 18, 2020 13:43:27.766 [0x7fbae25a1700] INFO - AutoUpdate: no updates available
Feb 18, 2020 13:43:33.227 [0x7fbb017e1700] ERROR - Unable to find title for item of type 5
Feb 18, 2020 13:43:35.723 [0x7fbae288f700] ERROR - [Transcoder] [mpeg2video @ 0x16e1580] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:35.725 [0x7fbae2b7d700] ERROR - [Transcoder] [mpeg2video @ 0x16e1580] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:35.726 [0x7fbae25a1700] ERROR - [Transcoder] [mpeg2video @ 0x16e1580] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:35.726 [0x7fbae19e9700] ERROR - [Transcoder] [mpeg2video @ 0x16e1580] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:35.727 [0x7fbae288f700] ERROR - [Transcoder] [mpeg2video @ 0x16e1580] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:35.727 [0x7fbae2b7d700] ERROR - [Transcoder] [mpeg2video @ 0x16e1580] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:35.763 [0x7fbae25a1700] ERROR - [Transcoder] [mpeg2video @ 0x16e1580] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:39.552 [0x7fbae19e9700] ERROR - [Transcoder] [mp2 @ 0x16e2940] Header missing
Feb 18, 2020 13:43:39.556 [0x7fbae288f700] ERROR - [Transcoder] [mp2 @ 0x16e4200] Header missing
Feb 18, 2020 13:43:39.556 [0x7fbae2b7d700] ERROR - [Transcoder] [mpeg2video @ 0x16e1580] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:39.783 [0x7fbae25a1700] ERROR - [Transcoder] [mp2 @ 0x16e8480] Header missing
Feb 18, 2020 13:43:41.527 [0x7fbae19e9700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:43:41.530 [0x7fbae19e9700] WARN - [FFMPEG] - No quality level set; using default (20).
Feb 18, 2020 13:43:41.535 [0x7fbae19e9700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:43:41.537 [0x7fbae19e9700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:43:41.540 [0x7fbae19e9700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:43:41.543 [0x7fbae19e9700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:43:41.779 [0x7fbae2b7d700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:43:41.813 [0x7fbae22b3700] ERROR - [Transcoder] [mpeg2video @ 0x2364d00] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:41.815 [0x7fbae25a1700] ERROR - [Transcoder] [mpeg2video @ 0x2364d00] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:41.817 [0x7fbae19e9700] ERROR - [Transcoder] [mpeg2video @ 0x2364d00] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:41.819 [0x7fbae288f700] ERROR - [Transcoder] [mpeg2video @ 0x2364d00] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:41.821 [0x7fbae22b3700] ERROR - [Transcoder] [mpeg2video @ 0x2364d00] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:41.823 [0x7fbae25a1700] ERROR - [Transcoder] [mpeg2video @ 0x2364d00] Invalid frame dimensions 0x0.
Feb 18, 2020 13:43:52.134 [0x7fbb02399700] ERROR - [TranscodeOutputStream] Session appears to have died from under us
Feb 18, 2020 13:44:32.339 [0x7fbb02687700] ERROR - Unable to find title for item of type 5
Feb 18, 2020 13:44:38.347 [0x7fbae0855700] INFO - CodecManager: obtaining decoder 'mpeg2video'
Feb 18, 2020 13:44:39.071 [0x7fbae0855700] INFO - CodecManager: obtaining decoder 'mp2'
Feb 18, 2020 13:44:39.559 [0x7fbae0855700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:44:42.522 [0x7fbae0567700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:42.769 [0x7fbabe4ef700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:43.015 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:43.731 [0x7fbabedb9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:44.219 [0x7fbabedb9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:44.469 [0x7fbabf395700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:45.100 [0x7fbabeacb700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:46.104 [0x7fbae19e9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:46.718 [0x7fbabe201700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:47.922 [0x7fbabe4ef700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:48.388 [0x7fbae19e9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:49.622 [0x7fbabe4ef700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:50.631 [0x7fbabe201700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:51.186 [0x7fbae0567700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:51.828 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:52.427 [0x7fbae288f700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:53.059 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:53.799 [0x7fbae19e9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:54.517 [0x7fbabdf13700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:55.227 [0x7fbabf0a7700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:56.429 [0x7fbae19e9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:58.201 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:44:59.502 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:02.747 [0x7fbabedb9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:03.774 [0x7fbabdf13700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:04.566 [0x7fbabdf13700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:05.312 [0x7fbae19e9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:06.252 [0x7fbae2b7d700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:07.494 [0x7fbae0855700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:08.576 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:09.887 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:10.666 [0x7fbae19e9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:12.452 [0x7fbabe201700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:13.613 [0x7fbae19e9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:15.156 [0x7fbabf395700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:16.639 [0x7fbabf395700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:18.740 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:20.290 [0x7fbae0567700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:22.617 [0x7fbabdf13700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:25.102 [0x7fbabedb9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:27.587 [0x7fbabe4ef700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:30.247 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:31.461 [0x7fbae2b7d700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:33.411 [0x7fbabf0a7700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:35.410 [0x7fbabe201700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:36.711 [0x7fbabe201700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:38.535 [0x7fbabedb9700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:41.175 [0x7fbabf395700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:42.972 [0x7fbabf395700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:45.622 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:47.577 [0x7fbae0855700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:50.814 [0x7fbabeacb700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:53.231 [0x7fbabe4ef700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:56.434 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:59.100 [0x7fbae0567700] ERROR - [Transcoder] [hls demuxer @ 0x13f6a00] Start sequence (105) is less than the previous (108).
Feb 18, 2020 13:45:59.668 [0x7fbb020ab700] ERROR - [TranscodeOutputStream] Streaming Session 0x7fbad4567010 appears to have died from under us
Feb 18, 2020 13:45:59.822 [0x7fbae19e9700] WARN - SLOW QUERY: It took 250.000000 ms to retrieve 51 items.
Feb 18, 2020 13:46:16.789 [0x7fbae3a23700] ERROR - Unable to find title for item of type 5
Feb 18, 2020 13:46:18.164 [0x7fbae1fc5700] ERROR - [Transcoder] [mpeg2video @ 0x20a5040] Invalid frame dimensions 0x0.
Feb 18, 2020 13:46:24.264 [0x7fbae0b43700] ERROR - [Transcoder] [mp2 @ 0x20ad500] Header missing
Feb 18, 2020 13:46:24.267 [0x7fbae1fc5700] ERROR - [Transcoder] [mp2 @ 0x20aac80] Header missing
Feb 18, 2020 13:46:24.269 [0x7fbae0b43700] ERROR - [Transcoder] [mp2 @ 0x20b1400] Header missing
Feb 18, 2020 13:46:26.014 [0x7fbabdf13700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:46:26.017 [0x7fbabdf13700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:46:26.021 [0x7fbabdf13700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:46:26.023 [0x7fbabdf13700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:46:26.218 [0x7fbabf395700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Feb 18, 2020 13:46:26.250 [0x7fbae288f700] ERROR - [Transcoder] [mpeg2video @ 0x11d6280] Invalid frame dimensions 0x0.
Feb 18, 2020 13:46:26.466 [0x7fbae2b7d700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:26.612 [0x7fbabedb9700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:26.903 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:27.350 [0x7fbae2b7d700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:27.414 [0x7fbabf395700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:28.268 [0x7fbae288f700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:28.756 [0x7fbae288f700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:28.981 [0x7fbabedb9700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:29.262 [0x7fbabf395700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:29.563 [0x7fbae288f700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:30.058 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:30.881 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:31.514 [0x7fbae288f700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:31.996 [0x7fbae2b7d700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:32.362 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:32.621 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:33.744 [0x7fbae2b7d700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:33.972 [0x7fbabdf13700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:34.981 [0x7fbae288f700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:35.355 [0x7fbae288f700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:35.686 [0x7fbae2b7d700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:35.916 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:36.644 [0x7fbae288f700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:36.911 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:37.376 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:37.656 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:37.876 [0x7fbabedb9700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:38.242 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:38.470 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:38.739 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:39.189 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:39.496 [0x7fbabedb9700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:40.520 [0x7fbabdf13700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:40.741 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:40.972 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:41.264 [0x7fbabdf13700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:41.574 [0x7fbabedb9700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:42.647 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:42.887 [0x7fbae288f700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:43.362 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:43.608 [0x7fbae2b7d700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:44.094 [0x7fbabdf13700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:44.321 [0x7fbae0b43700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:44.789 [0x7fbae1fc5700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:45.057 [0x7fbabf395700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:45.547 [0x7fbabf395700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:46.272 [0x7fbae2b7d700] ERROR - [Transcoder] [hls demuxer @ 0x11c3840] Start sequence (177) is less than the previous (179).
Feb 18, 2020 13:46:46.571 [0x7fbb02399700] ERROR - [TranscodeOutputStream] Streaming Session 0x7fbad4748960 appears to have died from under us
Feb 18, 2020 13:46:46.607 [0x7fbb01acf700] WARN - SLOW QUERY: It took 1120.000000 ms to retrieve 1 items.
Feb 18, 2020 13:46:55.926 [0x7fbae3d11700] ERROR - Unable to find title for item of type 5
Feb 18, 2020 13:46:57.228 [0x7fbabdf13700] ERROR - [Transcoder] [mpeg2video @ 0x230ad80] Invalid frame dimensions 0x0.
Feb 18, 2020 13:47:02.868 [0x7fbae1fc5700] ERROR - [Transcoder] [mp2 @ 0x2313040] Header missing
