Looking for some advice.
I know officially at this time load balancing between servers is not supported. I’ve seen various applications/load balancing firewalls/routers/software to incorporate this which I’ve seen poor results on or no longer supported.
Does anyone know of a currently developed method to load balance plex servers based on their current hardware load?
At present I have a setup where I got two different servers setup identically with the same local shares for transcode for friends (local on our network) where if one server is overly utilized I manually try my other server as do others when we experience buffering or over utilization. Realistically I would love a setup where it could automatically switch between the two based on usage.
I know I can setup this based on bandwidth load balancing, but this is not consistent for plex based on bandwidth each file requires, transcoding needs (hardware capabilities) etc.
Has anyone came across a method of doing this based on CPU/GPU usage that is still under development? I’m not 100% sure this is even achievable tbh without official support from Plex with back end communication.
For us die hard plex members I do find it kind of strange that there is not a method officially (based on my poor google skills) that can achieve this.
Has anyone found a means of this to monitor and LB based on hardware usage?
