Lately my plex has stopped adding new media automatically. i then tried via command line to get it to scan a section i knew there was something new in and it just returned with
****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.25.4.5487-648a8f9f9/PLEX MEDIA SCANNER/2c3ffdf6-ebb2-4c64-f4b9c3a4-b3da0f6e.dmp
Segmentation fault (core dumped)
And Segmentation fault doesn’t say me much. the weird thing just that when i try and scan any other section out of the 7 have then there is no issues, its only when i scan the 1 section
Had a peak inside the dump file and the only 2 things i noticed from those are
*** WARNING: Unable to verify timestamp for Plex Media Scanner
and
ERROR_CODE: (NTSTATUS) 0xb - An attempt was made to load a program with an incorrect format.
