Server Version#:
<If providing server logs please do NOT turn on verbose logging, only debug logging should be enabled>I’m a long time Plex Media Server user with a Plex pass and I’ve recently heard about the Plexamp app. Is Plexamp integrated into the media server now or is it completely separate? There is a music player on the media server and it does work, but I’m not sure if it’s the same app. I’m running through an Apple TV but it doesn’t support the separate plexamp app.
Plexamp is just a music-specific client. There is nothing different about the Plex server.
So the music player on the media server is the same as Plexamp?
No, it’s quite a different experience but using the same libraries from your server.
Just give it a try
Thanks for your reply. Unless I can use it through the Apple TV it wouldn’t be of use to me. I can use the media server that way but I don’t think there’s an app to integrate it into the Apple TV. I have Audirvana on the computer so I don’t need anything else there. Oh well. Thanks again though.
