@shiggins8 Please read this guide and check the settings in /etc/systemd/system/plexmediaserver.service.d/override.conf.
@uglymagoo Thanks for the quick response. Iād been using the systemd setup before and I hadnāt modified my override.conf file between installs. I ran āsystemctl daemon-reloadā and it just didnāt seem to make a difference. I had it installed on my Raspberry Pi 3, and I just couldnāt access it from any of my other devices even though it says itās up and running. Weird stuff.
Well to fix it I ended up just removing all the init.d styled scripts and doing a little manual rearrangement of things, but itās working now! Thanks again for always keeping your repo up to date!
Here is 1.9.3.
@shiggins8 Sorry, I totally overlooked your last post
I am glad you found the problem.
Iāve updated Plex on my raspberry Pi 2 to 1.9.0 first and then to 1.9.3. After the update Plex works but if I try to start/stop service this happens:
osmc@RaspberryPi2:~$ sudo /etc/init.d/plexmediaserver stop
Plex Media Server is not running (no process found)ā¦
osmc@RaspberryPi2:~$ sudo /etc/init.d/plexmediaserver start
Starting Plex Media Server: done
Any ideas?
Have you read up on systemd changes in this thread? I donāt believe the init.d is used anymore.
Try sudo systemctl daemon-reload
sudo systemctl stop plexmediaserver
sudo systemctl start plexmediaserver
sudo systemctl status plexmediaserver
Give a good read to this guide: https://forums.plex.tv/discussion/286395/customizing-your-plex-configuration#latest
Here is 1.9.5.
@uglymagoo any chance to have an update for the latest plex pass version:1.9.6.4385-ef7796e43 ?
Just wanna tell you that this package works pretty well on amlogic s905x
Thank you for the great work!
Tomorrow for sure, but today I will spend my whole day on a plane ![]()
Edit: Found some time at the airport. Here is 1.9.6.
Here is 1.9.6.4401.
Here is 1.9.7.4441.
hi all
Iām trying to change some settings in /lib/systemd/system/plexmediaserver.service but every time I update the server the changes are overwritten. How can I avoid this?
Thanks in advance
Francesco
@Francesco said:
hi all
http://forums.plex.tv/discussion/286395/customizing-your-plex-configuration
Here is 1.9.7.4460.
Here is 1.10.0.4523.
Here is 1.10.1.4561.
PMS is unable to see Hauppauge HVR-955Q when trying to set up Live TV/DVR. RPI3, any thoughts?
Your report is best placed in the TV/DVR subforum
@ChuckPA is right. But first try this simple solution: install the package firmware-linux-nonfree and perform a reboot afterwards. If your Hauppauge is still not recognized please create a new thread as @ChuckPA told you.
