Exit Code 127 on raspberry pi
So I followed this guide here and it went surprisingly smoothly, there were no errors while installing anything. When I restarted my Pi, I entered the IP followed by the plex port and everything, and nothing popped up, after googling I discovered the Plex server wasn’t starting and said exit code 127, I tried doing more googling but nothing I found was able to work
The armv6 Raspberry Pi is not supported, only the armv7 successors RPi 2 and 3. There is just no armv6 build of Plex available.
I should specify that I was using a RPi 2, but I also have a RPi 3
Please post the output of uname -a on your RPi 2 to make sure it’s really a RPi 2. Confusing a RPi Model B with a RPi 2 is the most common mistake here.
Also please post the output of journalctl -u plexmediaserver. If it’s really a RPi 2 it’s something you did during trying to install Plex and we have to figure out what went wrong.
Additionally, the guide you used is wrong in some aspects
(1) Editing /etc/default/plexmediaserver.prev just does nothing. I have no idea why the authors would think this is the correct file :smiley:
(2) Do not try to run Plex as user pi but just leave it as plex
‘uname -a’ gives
‘Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux’
I switched to my RPi3, but I still got a similar result on the Rpi2, and I looked on the board of what I thought was the RPi 2, and it did say it was the Pi 2 model B
And the other command says
'● plexmediaserver.service - Plex Media Server for Linux
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2018-02-10 20:14:45 MST; 10s ago
Process: 9490 ExecStart=/bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver "/usr/lib/plexmediaserver/Plex Media Serv
Process: 9487 ExecStartPre=/bin/sh -c /usr/bin/test -d “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” || /bin/mkdir -
Main PID: 9490 (code=exited, status=127)
Feb 10 20:14:40 raspberrypi systemd[1]: Started Plex Media Server for Linux.
Feb 10 20:14:40 raspberrypi systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=127/n/a
Feb 10 20:14:40 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
Feb 10 20:14:40 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Feb 10 20:14:45 raspberrypi systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Feb 10 20:14:45 raspberrypi systemd[1]: Stopped Plex Media Server for Linux.
Feb 10 20:14:45 raspberrypi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Feb 10 20:14:45 raspberrypi systemd[1]: Failed to start Plex Media Server for Linux.
Feb 10 20:14:45 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
Feb 10 20:14:45 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
‘uname -a’ gives
OK. So it’s not the hardware :slight_smile: So lets see what we can do
Did you do anything else, that’s not in the tutorial? Did you change the owner of /var/lib/plexmediaserver? Did you mount /var/lib/plexmediaserver on a network storage? Did you setup some process monitoring for Plex or auto reboot cron jobs or other crazy stuff, that I now some other tutorials advise? Please post the directory listing ls -al /var/lib/plexmediaserver/ and the contents of /lib/systemd/system/plexmediaserver.service and tell me anything that comes to your mind, that might be special about your installation.
Btw: you are using Raspbian as Operating System, right?
‘uname -a’ gives
‘uname -a’ gives
pi@raspberrypi:~ $ ls -al /var/lib/plexmediaserver total 12 drwxr-xr-x 3 plex plex 4096 Feb 7 23:44 . drwxr-xr-x 45 root root 4096 Feb 10 19:44 .. drwxr-xr-x 3 plex plex 4096 Feb 7 23:44 Library
`[Unit]
Description=Plex Media Server for Linux
After=network.target
[Service]
Environment=“PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/var/lib/plexmediaserver/Library/Application Support”
Environment=PLEX_MEDIA_SERVER_HOME=/usr/lib/plexmediaserver
Environment=PLEX_MEDIA_SERVER_MAX_PLUGIN_PROCS=6
Environment=PLEX_MEDIA_SERVER_TMPDIR=/tmp
ExecStartPre=/bin/sh -c ‘/usr/bin/test -d “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” || /bin/mkdir -p “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}”’
ExecStart=/bin/sh -c ‘LD_LIBRARY_PATH=/usr/lib/plexmediaserver “/usr/lib/plexmediaserver/Plex Media Server”’
Type=simple
User=plex
Group=plex
Restart=on-failure
RestartSec=5
StartLimitInterval=60s
StartLimitBurst=3
[Install]
WantedBy=multi-user.target`
and yes I am using Rasbian , figured that would be the easiest,it was also brand new when I started trying to install Plex
[Install]
Everything looks good so far and the Library was created, so I hope Plex did also create a useful log file in /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.log. Please post the contents of this file.
Please also try to restart plex with sudo systemctl restart plexmediaserver and then post the new contents of the above mentioned log file.
[Install]
There’s nothing in /var/lib/plexmediaserver/Library/Application Support/ even when I use that command
Please issue sudo systemctl restart plexmediaserver again, take a look at the output of journalctl -u plexmediaserver again and also at sudo dmesg. Please also check the free memory with df -h and post the output. I have the suspicion, that there is something wrong with your sd card. Did you use the same sd card on your RPi 2 and 3?
My post was over 4,000 characters too long, so here’s a link pastebin.com/W2hqKbUW
There it is:
/bin/sh: 1: /usr/lib/plexmediaserver/Plex Media Server: >!not found
The package installation was for whatever reason unsuccessful and the binaries are completely missing :smiley: Did you disrupt the package installation? I am quite sure there was an error message or warning. To fix this please try to reinstall my package and post the complete output:
sudo apt-get install --reinstall plexmediaserver-installer
There it is:
I ran that and got
Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 51 not upgraded. 2 not fully installed or removed. After this operation, 0 B of additional disk space will be used. E: Internal Error, No file name for plexmediaserver-installer:armhf
so I tried installing plexmediaserver-installer and
pi@raspberrypi:~ $ sudo apt-get install plexmediaserver-installer Reading package lists... Done Building dependency tree Reading state information... Done plexmediaserver-installer is already the newest version (1.10.1.4602-f54242b6b-1). plexmediaserver-installer set to manually installed. 0 upgraded, 0 newly installed, 0 to remove and 51 not upgraded. 2 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] y Setting up plexmediaserver-installer (1.10.1.4602-f54242b6b-1) ... Downloading readynas package ... ######################################################################## 100.0% Passed checksum test. Extracting readynas.deb ... Synchronizing state of plexmediaserver.service with SysV service script with /lib/systemd/systemd-sysv-install. Executing: /lib/systemd/systemd-sysv-install enable plexmediaserver Job for plexmediaserver.service failed because the control process exited with error code. See "systemctl status plexmediaserver.service" and "journalctl -xe" for details. Setting up plexmediaserver (0.9.16.4.1911-ee6e505-2~jessie) ... W: APT had planned for dpkg to do more than it reported back (3 vs 7). Affected packages: plexmediaserver-installer:armhf
when I now try to start it it says
pi@raspberrypi:~ $ sudo systemctl restart plexmediaserver Job for plexmediaserver.service failed because the control process exited with error code. See "systemctl status plexmediaserver.service" and "journalctl -xe" for details.
`pi@raspberrypi:~ $ systemctl status plexmediaserver.service
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/plexmediaserver.service.d
└─override.conf
Active: failed (Result: exit-code) since Sun 2018-02-11 16:41:10 MST; 3min 47s ago
Process: 1134 ExecStartPre=/bin/sh -c /usr/bin/test -d “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” || /bin/mkdir -p "${PLEX_MEDIA_SERVER
Main PID: 4677 (code=exited, status=127)
Feb 11 16:41:05 raspberrypi systemd[1]: plexmediaserver.service: Control process exited, code=exited status=217
Feb 11 16:41:05 raspberrypi systemd[1]: Failed to start Plex Media Server for Linux.
Feb 11 16:41:05 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
Feb 11 16:41:05 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Feb 11 16:41:10 raspberrypi systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Feb 11 16:41:10 raspberrypi systemd[1]: Stopped Plex Media Server for Linux.
Feb 11 16:41:10 raspberrypi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Feb 11 16:41:10 raspberrypi systemd[1]: Failed to start Plex Media Server for Linux.
Feb 11 16:41:10 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
Feb 11 16:41:10 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
and the other command’s results can be found here pastebin.com/ye9mxFPz
Setting up plexmediaserver-installer (1.10.1.4602-f54242b6b-1) …
As I told you, you had disrupted the original installation and the package state was in limbo :wink: And by trying to fix this you made things worse. It’s best just to start from scratch:
# remove everything plex related
sudo apt-get purge plexmediaserver-installer
sudo rm /etc/systemd/system/plexmediaserver.service.d/override.conf
sudo rm /etc/default/plexmediaserver
# install plex from scratch
Edit: I did not read your first comments correctly and removed my wrong remarks :blush:
That finally worked, thanks
