Server Version#: 1.32.8.7639
I run Plex server from Truechart repository for Truenas Cobia. Ixsystems removed openvpn service from Cobia so I use GlueTun addon for vpn connection. I need vpn since I am under NAT of mobile networks and I can´t forward ports). Basically Plex server and Gluetun are parallel containers in docker. The connection to openvpn server works, curl ip.me from Plex container reports the server address (the vpn tunnel works). But the plexapp running from the container reports the client ip address like it does not use the vpn of GLuetun
