Been testing on a few clients (xbox one, ios, web, roku) and have some feedback. Running PMS on a Synology DS916+ 8GB.
What works works very well. Most issues I’ve encountered are with MPEG2 -> h264 transcoding
When resuming, Plex does not always do a full hw transcode. It does when starting from the beginning. This leads to buffering as sw->hw transcoding uses just one of the 4 cores on the NAS which it can’t handle. While sw->sw works on this unit (with all cores), sw->hw does not. A setting to have full sw transcoding when full hw transcoding is not available would be nice.
h264->h264 hw transcoding works great. However I’m getting VERY long buffering on MPEG2->h264 (DVR recordings), with rebuffering every few seconds/minutes. This is the same behavior I see when doing a sw->hw transcode, only the status on the settings page does show hw->hw. CPU seems to be the same either way (around 25-30%)
Live TV is failing on XBOX One with this version only. After a long wait it says the transcoder fails.
Also I’m curious, does the “Transcoding Quality” setting affect quality when hardware decoding?
I’ve attached logs that should show #2 and #3. If you need sample video files please let me know. But this is the same with all MPEG2 recorded content that I’ve tested.
I’m having huge issues optimizing videos in a folder. I don’t see any obvious correlation between what does optimize and what doesn’t. I’m part way through 140 moives and 53 have already failed optimization. I have attached my log files.
E3-1220L (no intel QV)
Geforce GT 1030
Ubuntu 16.04 Server
Still no joy transcoding, am I here too soon :neutral:
I looked at your other post and are your trying to do hardware transcoding?
If so you can’t with most xeon processors as they don’t support quick sync. As far as I know that is a requirement regardless of offloading to the GPU or not.
Geforce GT 1030
Ubuntu 16.04 Server
@Essam01 said:
Improved quality of HW transcoding on Synology DS918+
Could you elaborate on that please?
with 1.12.0 and HW decoding enabled, the playback of hevc coded media (even at only 3.6 Mbps) is quite pixelated (takes very long until it starts, very low quality); with 1.12.1 is much less but actually still low quality and still takes ages to start playing. That is why I said “improved” and not good.
For comparison purposes, the same media played (transcoded) with a MacBook Pro (core i7, 2012) is excellent. HEVC playback is generally not very good even with the “other Green Server”
Hope this helps
Mar 13, 2018 05:08:53.214 [8184] ERROR - [FFMPEG] - The minimum required Nvidia driver for nvenc is 378.66 or newer
Mar 13, 2018 05:08:53.214 [8184] WARN - avcodec_open2 returned -1313558101 for encoder ‘h264_nvenc’
Mar 13, 2018 05:08:53.214 [8184] WARN - Failed to find encoder ‘h264_mf’
Mar 13, 2018 05:08:53.277 [8184] WARN - Failed to find encoder ‘aac_mf’
Mar 13, 2018 05:08:53.277 [8184] WARN - Failed to find encoder ‘mp3_mf’
Mar 13, 2018 05:08:53.277 [8184] WARN - Failed to find encoder ‘hevc_mf’
Mar 13, 2018 05:08:53.339 [8184] WARN - Failed to find encoder ‘aac_mf’
Mar 13, 2018 05:08:53.339 [8184] WARN - Failed to find encoder ‘mp3_mf’
Typo in the ffmpeg string?
the encoder should be h264_amf, hevc_amf, etc etc for AMD. I’m not even sure what aac_mf or mp3_mf are supposed to be, there’s no hardware audio transcoding.
the _mf stands for Media Foundation which in the context above, we could not find the system provided codecs (which we can use in place of the ffmpeg ones) these are not the “Hardware” accelerated codecs.
for h264_nvenc that is the Nvidia Encoder provided by the Nvidia Driver, which FFMPEG can use via VAAPI if I understand correctly.
I am assuming you don’t have an Nvidia card in your system, so that error above may be the Plex Transcoder looking for h264_nvenc which results in a check for the Nvidia driver which you don’t have.
Windows task manager confirms that there’s 0% usage on the GPU video encoder but about 20-30% usage on the decoder.
Not exactly the same issue on my Core-i7 8700K : the HW transcoding is working, but never using more than 40%-50% of the GPU capabilities, making it impossible to transcode 4K HEVC content with HW Transcoding, so I was forced to disable it. It was encoding the same movies at around 2x factor with HW transcoding before.
Yeah, I have a DS916+. I gave it a shot, and it seems to be working great! I’m showing MPEG2(HW) to H264(HW) on a remote live tv stream. This is what I’ve been waiting for!
One small issue, although I don’t know if it’s related to this release at all, is I have the “Remote Access” setting for Limit Remote Stream set to 3Mbps 720p, but I’m only able to select up to 1.5Mbps 480p remotely. And yes, I’m testing on an HD station (several).
Update: Scratch that comment. It’s totally working. I had set Remote access to 1.5Mbps, and changed it to 3Mbps. Once I closed the tab and reopened, I was able to stream 3Mbps remotely.
