jstock
December 25, 2019, 3:20am
1
Server Version#: 1.18.3.2129
I rebooted a FreeNAS custom FreeBSD 11.3 jail last night and since then, the PMS won’t start.
I’ve checked Logs/Plex Media Server.log, /var/log/messages, tried turning on RC debug and everything points towards it should run but it doesn’t.
Executing the binary /usr/local/share/plexmediaserver-plexpass/Plex_Media_Server just hangs with nothing becoming available via the web interface.
I’ve also reinstalled the pkg from the pkg source and also updated to the newest .tar.bz2.
I can’t find any other sensible source of logging as to what might be causing this.
Any suggestions/help please? I do have verbose and debugging logging turned on prior to the failure, so happy to provide what I can.
Thanks in advance.
Can you try sockstat -l46 (on the jail) and check if anything is listening!? If not it definitely didn’t start or stopped after.
Btw since its a custom jail, how did you install pkg? Or ports!?
jstock
January 5, 2020, 12:06am
3
Hi Mike_CT and others who might be lurking,
I installed via pkg. It turned out that I had some corrupt data somewhere in my previous install. I never worked out where it was, but it definitely wasn’t in:
Cache
Metadata
Thumbnails
I know Plug-ins and Plug-in Support had issues but in the end I just gave up and rebuilt my library from scratch.
Thanks for the support thought! I appreciate you getting back to me.
system
Closed
April 4, 2020, 12:06am
4
