Plex + NAS server build help
H all-
I’d like to build server that will be used for a few purposes:
  • Plex Server
  • Retire an old netgear readynas. It has 4 drives with videos running in jbod config. I’d like to move those drives over the new server.
  • Cetral log server for my home. Probably run something like Graylog
  • Docker experimentation
Here is what I’m thinking right now. Would appreciate some feedback:
  • CPU - i3 10100
  • motherboard - ASRock H410M-HDV/M.2 Micro ATX LGA1200
  • RAM 16GB
  • HHD - 256 GB SSD (already own), 4 drives from NAS, maybe one additional 4tb drive for log data and docker images.
  • Case - Chenbro Rackmount 4U Server Chassis RM42300-F (already own)
  • CPU cooler TBD
  • Sata expansion card - TBD
  • Power supply - TBD
Would love you get your overall thoughts on this setup. I’d also appreciate any specific recommendations on PSU and sata expansion. I want to make sure I have enough for at least 6 drives, but don’t need a monster that’s gonna drive up the electric bill either.
I found this useful for which CPU to choose since the CPU seems to be the biggest factor in Plex performance: What kind of CPU do I need for my Server? | Plex Support
I run Synology NAS devices myself so I’ll leave additional suggestions to other more knowledgeable hardware folks. :slight_smile:
I have been running unraid for a few years and I like it. Might check in to it to see if it might be a fit for you.
Yes, I’ve been thinking about using Unraid. Can you still run hardware acceleration for plex from unraid? With that 10th generation intel CPU I’m planning on taking advantage of the QuickSync to handle transcoding.
Yes you can use QuickSync, I have seen instructions on how to set it up but I do not use it since I have a AMD processor. You can also use GPU transcoding from supported graphics cards as well.
