Server Version#: 4.148.0
Player Version#: 2025.24.0
I record videos on my iPhone 16 Pro (iOS 18) with audio in “Spacial Audio” format (see Settings→Camera→Record Sound). I don’t remember if this is the default or not. When this is set, iOS creates two audio tracks, with APAC (Apple Positional Audio Codec) as the default, and AAC (stereo) as alternate. APAC as recorded is either 3.1 or 4.0 surround (I’m seeing it both ways in the docs and UI).
I’ll often import these recordings via Image Capture, and save them to my Home Videos folder which is a Plex library.
When I attempt to play these videos on my Apple TV 4K, Plex shows an error:
Could not transcode because:
Cannot convert this item.
Implementation for audio decoder
‘apac’ not found.
I can manually change the audio channel to AAC, which plays fine. While I can hear the audio, it’s using two-channel stereo rather than surround (positional) as is the audio’s intent. The AppleTV (as of tvOS 17, from fall 2023) has a built-in decoder for APAC audio.
Primarily I am curious what steps are required on the Plex development side to play APAC audio. My primary use is on Apple TV, but the format should be translatable in some way to other formats. I’m happy to help if possible.
Secondarily, I’m wondering why Plex doesn’t try the two-channel AAC audio when it recognizes it cannot play the primary APAC audio channel. This leads to me changing the audio channel for each video, which gets old fast.
I encounter the same issue when using Plex’s web client. I’m less surprised Plex web cannot play APAC, but again I’m surprised it doesn’t simply play the AAC audio.
If helpful, Apple’s documentation on the APAC format is here:
