PLEX not able to stream any content without buffering (Direct Play + Direct Stream = active)
Both = done
how long ago did you update your android tv
Android-TV is automatically checking for updates and today I also checked manually for updates - nothing available
And, before asking, ALL software I am using is up-2-date
it looks very strange
for me situation with plex problem looks not so strange but why VLC does not work fine
may be we will look more deeper?
do you know how to work with command line in windows pc?
One second:
Just tried VLC on mobile - ha, working now! Maybe it is working while DLNA just switched on on PLEX-server!
Will try it on TV, too
Command line on PC → not that much
try on tv
Hmmm, not sure what you wrote :slight_smile: but I will try on TV soon
VLC on TV is saying content can not be played :open_mouth:
One sec, will try smth
Ha, on TV, series are working now AND movies, too
Very strange behavior! Will try 4K tmr, too. Thanks a lot
Will keep u posted
VLC works?
or
PMS works?
on your TV
Using VLC on TV! Picked the folders with content, put login-data and tried content - working
when you use pms on tv you must check the message of dashboard
PMS on TV not working
I am using VLC while picking NAS, then the ‘shared’ folders, content playing
pms is working but with buffering
we need to know why
that is why we need to check dashboard
PMS is not showing content. It is loading so long. Will let it run and check play tmr morning. Will reply then.
Thanks so far and keep u posted tmr morning
