Debian 12 (Bookworm) (Headless)
Player Version: 1.40.4.8679
I’m running headless Debian and I realized that I now have an issue where Plex won’t detect my GPU. Before this it would detect my GPU just fine and I have all my GPU drivers updated and everything but it still won’t detect it.
I have the NVIDIA GM107 [Geforce GTX 750 Ti] and it appears [inxi -G] is not detecting the drivers but it’s also saying I have the drivers installed (535.183.01). And this all used to work completely fine before.
[chuck@glockner ~.2004]$ dpkg -l | grep nvidia | grep 535
ii libnvidia-cfg1-535-server:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-535-server 535.183.01-0ubuntu0.22.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-535-server:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-decode-535-server:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-535-server:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-535-server:amd64 535.183.01-0ubuntu0.22.04.1 amd64 Extra libraries for the NVIDIA Server Driver
ii libnvidia-fbc1-535-server:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-535-server:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-535-server 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-dkms-535-server 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-535-server 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA Server Driver metapackage
ii nvidia-firmware-535-server-535.183.01 535.183.01-0ubuntu0.22.04.1 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-535-server 535.183.01-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-535-server 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA kernel source package
ii nvidia-utils-535-server 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA Server Driver support binaries
ii xserver-xorg-video-nvidia-535-server 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA binary Xorg driver
[chuck@glockner ~.2005]$
The GSP firmware has been enabled by default in the 555 series, and can be disabled by adding nvidia.NVreg_EnableGpuFirmware=0 to your kernel boot parameters .
How do I disable GSP firmware?
The GSP firmware has been enabled by default in the 555 series, and can be disabled by adding nvidia. NVreg_EnableGpuFirmware=0 to your kernel boot parameters.May 25, 2024
Try to disable it? You do have a an older GPU (it’s the oldest on their list of supported)
NVIDIA GeForce GTX 750 Ti Specs | TechPowerUp GPU Database
The GeForce GTX 750 Ti was a mid-range graphics card by NVIDIA, launched on February 18th, 2014. Built on the 28 nm process, and based on the GM107 graphics processor, in its GM107-400-A2 variant, the card supports DirectX 12.
They might have dropped it from the supported list
