For some reason Plex crashed this morning which has been the first time this happened. On inspection I discovered that my /var partition was full, which was strange. After a bit of research I discovered that the video thumbnails was probably the culprit, however I couldn’t get onto the server to change this setting then optimise the database. This lead to me needing to uninstall PMS then reinstall it. This completed with a few errors, however when I type in “start_pms” the server starts fine. The only issue is that I have to type that into terminal in order to get it to start as it seems the errors that occurred were that it didn’t install the services for some reason.
I just need to know if there is anyway that I can create these myself.
[Install]
WantedBy=multi-user.target
run sudo systemctl start plexmediaserver
check that there are no errors and it’s still running with sudo systemctl status plexmediaserver
Then make it run on restart sudo systemctl enable plexmediaserver
