Server Version#: 1.24.3.5033
Player Version#: 1.35.1.2632-c6783c78
I’m running my Plex server with a pretty beefy CPU, the EPYC 7502P, but for massive h265 movies it only uses 20% CPU and is only able to transcode at 0.8 times playback speed, resulting in buffers.
Does Plex not use the full CPU or is it limited by something?
Then HW accelaration would be whatever your hardware makes availiable like Quick-Sync or similar… But is it not given thta you have any compatible Hardware that support HW accelaration…
The “Plex media server.log” will show info about your plex server installation and general info. trancoder statistics should show what the trancoder is doing. But generally I think the suggestion is to upload the zip file.
Although I appreciate the help, I’m not uploading files with the IPs of me and everyone who uses my Plex server to the internet, so could you tell me what lines I would be looking for that would display this issue?
I don’t see that exact log, this is all “INFO” returns for me
Oct 05, 2021 09:38:27.647 [0x7f38a0023b38] INFO - Plex Media Server v1.24.3.5033-757abe6b4 - Docker Docker Container (LinuxServer.io) x86_64 - build: linux-x86_64 debian - GMT 00:00
Oct 05, 2021 09:38:27.648 [0x7f38a0023b38] INFO - Linux version: 4.19.0-17-amd64, language: en-US
Oct 05, 2021 09:38:27.648 [0x7f38a0023b38] INFO - Processor AMD EPYC 7502P 32-Core Processor
Oct 05, 2021 09:38:27.648 [0x7f38a0023b38] INFO - Compiler is - Clang 11.0.1 (https://plex.tv e0c29d5827bc4eaaa2ceb882cbeed224b0960173)
Oct 05, 2021 09:38:27.648 [0x7f38a0023b38] INFO - /usr/lib/plexmediaserver/Plex Media Server
