Plex not working after power outage
So when it tells me if I want to create a new server I do?
Screenshot please?
EDIT:
Plex.tv sees your server again attached to your account:
CREATED ALMOST 2 YEARS AGO
LAST SEEN 1 MINUTE AGO
Didn’t ask actually, it shows this (my actual libraries):
You’re still in the incogito window? If yes, it will do this.
This is the Plex/web browser setting itself up.
Nothing will be remembered – “FINISH” i
You can now close the window and reopen the browser normally.
Oh my god, it’s fixed! I can’t thank you enough, you have no idea how grateful I am!
Check all your settings – be 100% certain :slight_smile:
So it seems to be transcoding when using the web player, which is kind of strange
It depends on the media.
Browsers usually only accept AAC audio.
Some browsers allow HEVC but others do not.
Settings - Server - Transcoder - Show Advanced
This will let you confirm what should be.
I’ll try on my TV, give me a sec
Yes! Everything is working properly then! I do have one last question if you would be so kind: I’m having trouble updating the server version, because everytime I download it, it tells me that the same package is available through the Ubuntu software store, but I can’t upload it from there either
Because you’re using the one from plex.tv/downloads – IGNORE the ubuntu store.
What we did here (remove the ubuntu store package) should quiet that update notification.
PMS telling you there is an update available – That happens almost constantly.
The version you’re on is VERY stable. For now, I recommend staying with it.
Settings - Server - General
Make certain you’re set to Public.
When you do decide to update
  1. Download from plex.tv/downloads
  2. The file will end up in your Downloads directory
  3. From the Terminal window:
cd Downloads
sudo dpkg -i  plexmediaserver_X.XX.XX.XXXX-*.deb
Substitute the real version number for the “X” above.
You’ll see the installer run
Thank you soooo much! You’ve been a lifesaver
Here is my test machine. Ignore the warning :slight_smile:
[chuck@lizum Downloads.2021]$ sudo dpkg -i plexmediaserver_1.28.1.6041-*.deb
dpkg: warning: downgrading plexmediaserver from 1.28.2.6106-44a5bbd28 to 1.28.1.6041-738907df3
(Reading database ... 213270 files and directories currently installed.)
Preparing to unpack plexmediaserver_1.28.1.6041-738907df3_amd64.deb ...
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.28.1.6041-738907df3) over (1.28.2.6106-44a5bbd28) ...
Setting up plexmediaserver (1.28.1.6041-738907df3) ...
PlexMediaServer install: PlexMediaServer-1.28.1.6041-738907df3 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install:   Installation Type:   Update
PlexMediaServer install:   Process Control:     systemd
PlexMediaServer install:   Plex User:           plex
PlexMediaServer install:   Plex Group:          plex
PlexMediaServer install:   Video Group:         render
PlexMediaServer install:   Metadata Dir:        /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install:   Temp Directory:      /tmp
PlexMediaServer install:   Lang Encoding:       en_US.UTF-8
PlexMediaServer install:   Processor:           Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
PlexMediaServer install:   Intel i915 Hardware: Found
PlexMediaServer install:   Nvidia GPU card:     Not Found
PlexMediaServer install:   OpenCL:              Installed
PlexMediaServer install:   Beignet:             Installed
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: INFO: Plex Media Server is not enabled to start at system boot.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.28.1.6041-738907df3 - Installation successful.  Errors: 0, Warnings: 0
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for mime-support (3.64ubuntu1) ...
[chuck@lizum Downloads.2022]$
