Plex Notify
The above makes perfect sense, cheers for the explanation.
I've posted the bug report https://forums.plex.tv/topic/97575-statussessions-viewoffset-problem/
Cool, any news on when you update will go live to fix the recurring update box ;-)
Tonight with the database fix
Good man cheers
BTW, to avoid this in meantime, just restart app and don't check update...
The update is out. Just as a friendly reminder this update wipes your database.
A lot of MySQL errors still
    You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '1 * FROM INFORMATION_SCHEMA.COLUMNS WHERE TABLE_NAME = 'PlexNotifyClients' AND C' at line 1
      at MySql.Data.MySqlClient.MySqlStream.ReadPacket()
   at MySql.Data.MySqlClient.NativeDriver.GetResult(Int32& affectedRow, Int64& insertedId)
   at MySql.Data.MySqlClient.Driver.GetResult(Int32 statementId, Int32& affectedRows, Int64& insertedId)
   at MySql.Data.MySqlClient.Driver.NextResult(Int32 statementId, Boolean force)
   at MySql.Data.MySqlClient.MySqlDataReader.NextResult()
   at MySql.Data.MySqlClient.MySqlCommand.ExecuteReader(CommandBehavior behavior)
   at MySql.Data.MySqlClient.MySqlCommand.ExecuteReader()
   at PlexNotify.Databases.MySqlDB.RunReturnQuery(String sql, Dictionary`2 sqlParameters)
    Unknown table 'plexnotify.user'
   at MySql.Data.MySqlClient.MySqlCommand.ExecuteNonQuery()
   at PlexNotify.Databases.MySqlDB.RunQuery(String sql, Dictionary`2 sqlParameters)
    Unknown table 'plexnotify.settings'
    Table 'servaraliases' already exists
    Table 'plexnotify.user' doesn't exist
Holly crap. I just had to push 2 updates. I should have fixed your problem I inadvertently introduced the uber update notify bug. I hotfixed it.
I am happy to announce that Plex Notify is an official Pushalot application now! https://pushalot.com/sources
was your issue fixed?
no, tested again and notifications still doesn't work (0.0.0.11):
PlexNotifyLog>
    Application started.
    Specified cast is not valid.
      at PlexNotify.DatabaseHelper.RegisterClientWithDatabase()
   at PlexNotify.MainWindow..ctor()
duplicate post
duplicate post
use MySql workbench to delete your database and re-create it. servaraliases error will come up that is a bug.
The app is crashing on my computer. I get the force close screen on Windows, the following app has stopped working, I've attached the files that it claims are related to the issue. I also have another file that is too large to be uploaded to the forum so I've uploaded it to my domain. This is the link to that file. Its called WERF969.tmp.mdmp. Hope this helps if you need any additional information please let me know.
I am getting the same errors as sfnetwork. Closed Plex Notify, recreated db, same issue.
Edit
Make sure users have permissions.
So I was trying to use mysql db instead of mssqlce once I go back to ce it works fine.
Are there any logs in "C:\ProgramData\Plex Notify\Logs"
Ok I have a fix in place. I changed all tables to have primitive TSQL data types. publishing now.
What a crazy night. Im heading to bed. I hope everything is working ok for you guys now. Seems to be working great on my local MySql. Lessons learned tonight. I think we are done with the database problems and update problems. I will start creating more statistics content tomorrow.
What fix was that for? Is it so we can use mysql instead of mssqlce?
