Plex Notify
Sorry about that I fixed it.
haha also i realized I pushed alot more in that update that I wanted to Like all the Webserver stuff and new buttons on the Stats screen that wont work right now. I just published my Dev environment.
confirmed, images work again  :)
not sure if related but nothing works now lol (no posters anywhere)
    There is an error in XML document (1, 2).
      at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
   at System.Xml.Serialization.XmlSerializer.Deserialize(TextReader textReader)
   at PlexNotify.Core.XmlDeserializeFromString(String objectData, Type type)
   at PlexNotify.Core.XmlDeserializeFromString[T](String objectData)
   at PlexNotify.PmsFactory.GetMediaInformation(String url, PlexUrl pu, Boolean updateGet)
    There was a problem deserializing the response XML
    <![CDATA[Unauthorized
401 Unauthorized
    <html xmlns=''> was not expected.
      at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMediaContainer.Read17_MediaContainer()
401 Unauthorized
401 Unauthorized
401 Unauthorized
Hope this is related,it was working fine this morning, came back to "Application cannot be started. Contact the application vendor"
401 Unauthorized
401 Unauthorized
401 Unauthorized
401 Unauthorized
Looks like you are not logged in on your plex server with your plexpass account its saying you have unauthorized access to the Sessions page. open a web browser and see if you can get to http:\\*IP*:*Port*/status/sessions
Did you try re-opening it? Can you send me the logs? C:\ProgramData\Plex Notify\Logs
Ah shi*** I enabled the "required authentication in local network" this morning...
So this is where logon to MyPlex gets affected...
I really need to find my permission issue...
If only related to this.... other PC which logon fine had same issue... (but problem PN was primary so...)
This you test with this setting from PMS?
Yep i reopened it and it's back to Alpha v0.0.0.26
Seems to be working ok so far again.
If it happens again i'll send you the log file.
Could someone send me a copy of their Sqlite Plex Watch Database? Im goint ti see if i can add in a migration option.
This would be HUGE!
I was just wondering this morning. I have a large 3 month or more history I can send when I get back to my office…
Thx!
Good news everyone, on todays release I am adding the ability to import your PlexWatch databases. You will not get the full audit trails when viewing Video detail from them, but users, views, View time and players will be imported.
Not sure how to add images to individual user profiles. I am using the Firefox SQLite Manager plugin (https://addons.mozilla.org/en-us/firefox/addon/sqlite-manager/) to customize Plex section icons as instructed by the How-To: Plex Media Server: Change the Section Icons (http://raspberrypihtpc.wordpress.com/how-to/how-to-plex-media-server-change-the-section-icons/) Do I have what I need to add an image to a user?
This info came from the Feature Request: Custom Library Icons thread (https://forums.plex.tv/topic/63617-feature-request-custom-library-icons/) post #4.
in settings, go to the User Tab, click the Set button next to the user you want to set the image for.
JBurlison@Gmail.com, on 10 Feb 2014 - 5:29 PM, said:snapback.png
I managed to get the images for users without a SQL Manager. I resized an image (using GIMP, http://www.gimp.org/) to the size that was acceptable in the Users Settings of Plex Notify. A simple fix that really makes the app more professional looking.
Its working =>
a few more tests and I will push the update.
Its working =>
After much heartache I got this to work WITH audit trails. Only the best for you guys. Some minor UI adjustments now and Ill push the release.
Awesome stuff!
ANNNNDD updated.
