Keep getting lots of notifications - every 3 seconds - from a couple of of my users explaining they resumed what they are watching every few %.
restart plex notify. thats a bug
Bunch of those
Bunch of those
0.0.0.43Object reference not set to an instance of an object.at PlexNotify.DatabaseHelper.SaveMovieInfo(DatabaseInterface dbi, Video v)Object reference not set to an instance of an object.at PlexNotify.DatabaseHelper.SaveMovieInfo(DatabaseInterface dbi, Video v)
Thanks. I found the issue. it will be resolved next build.
I figured that, but restarting and it carries on. On .43 BTW
Loves the real estate on my screen too. lol
Sent from my HTC One using Tapatalk
I found this bug! It will be corrected in tonights release!
So what was happening before any buffering status's where coming over as paused. So if you where getting spammed with pause.... that's why.
Did you do something with channels? I was just watching one and the info came over to my phone.
Sent from my XT926 using Tapatalk
Is this good or bad?
I did fix a couple notification bugs this release.
Sent from my SM-N900P using Tapatalk
hey jbur, any chance of releasing this app as a service? that way it'll be able to run even before the user logs in. Would be sweet :)
There is a lot of technical challenges with that. I'd have to look into it. You would definitely lose auto updates in its current form and I would have to host them, witch costs money. This wouldn't be anything implemented any time soon.
For now just have your computer auto login when it starts.
Ok, i'll keep doing that. Thanks!
Alpha v0.0.0.45
- Minor UI teaks for truncated data.
- Plexwatch import is now 100% working!!!!
Good, just unexpected
Is it possibe to get notifications on PMS start/stop?
The connection error setting will tell you if the PMS cannot be reached. I can put another setting in for when connection has been restored.
ah yes I see. I stopped the PMS and got HAMMERED with connection lost notifications :)
Yeah Im going to change that to a time based notification rather than occurrence so i your not around you dont get spammed to death.
That would be useful, thanks.
if your're adding an event for connection restored detection, I would consider sending only one of those connection lost notifications.
