Plex Notify
I don't know if it's because I'm on MySQL but it's really painful to wait when I simply want to see the event logs:
-Open statistics; wait like 15-20 sec before seeing anything (that's very long IMO)
-Go to Log events: another 6-7 sec
That's almost 30 secs just to go in event logs....
Wasn't like that before (not sure which version though)
Now, I'm avoiding going there and use PushOver on my iPhone to quickly see the log of event...
Sorry, if my question seems stupid, just trying to understand, what exactly is "parsing". Is it the images? Because the data is there in the SQL database with the indexes, etc.. ready to be shown so I don't understand the loading purpose.
Again, sorry if this question seems dumb, I'm not trying to be annoying here, just curious  :)
Is there any plan to improve this...
This will be faster.
Sent from my SM-N900P using Tapatalk
Just pushed some bug fixes:
Alpha v0.0.0.64
 - Fixed detection for video watch "Re-starts"
 - Fixed some cases where notifications would be infinitely sent out.
 - Fixed memory leak in Stats page
 - Fixed some versions of windows not being able to connect to MyPlex.
Seems my solution for the memory leak only works in debug. Back to the drawing board.
Alpha v0.0.0.64
Thank you!!! PN is connected to MyPlex successfully for the first time ever on my Win 2008 R2 server!  :D
Alpha v0.0.0.64
Just FYI my CPU has been pegged at 50% all day today whilst Plex Notify is running. Started with the update (I got a notification and I noticed the CPU fans seemed a little loud, thought it was transcoding something for a user, but it was still like that when I got back to the house a few hours later). Plex Notify seems to be working but I can't figure out why the 50% CPU usage. Reboot etc doesn't seem to fix it.
EDIT: should add, running Windows 7 32 bit, all previous versions of PN were fine. Latest Plexpass PMS. I found a log file but it seems only to have data a week old in it; if you want it please let me know how to get you a useful logfile.
I sew what happened. I have some unfinished code in there. I will push a fix for this tonight. Sorry.
Thanks for the ninja response!
I really like Plex Notify, it's one of those utilities that runs quietly in the background letting me know when other users are playing stuff in my library. I use the Pushalot integration with my Windows Phone by the way and it works really well. Thanks again.
Any chance I can see when a user is browsing my server for Movies or Television. I would like to be notified if I have any active connections. Thanks.
No, sorry not without parsing log files.
Hi, I really love this app!
Would it be possible to sort the TV-Shows/Movies in the statistics tab so that the shows/movies with most views is at the top?
Alpha v0.0.0.66
 - Fixed memory leak in Stats page *Really this time*
 - Fixed some cases that would cause High CPU Usage.
 - Added a garbage collect button to settings.
 - Improved stats window load time.
Hi James, I am running your Alpha v0.0.0.67 in Windows 8.1, but I have a crash error from your application when I click in statistics Movies windows. You can see here:
http://prntscr.com/3hz5vk
Your .log file does not tell me nothing:
    0.0.0.67
    Application started.
Any suggerences?
Regards
Paco
    0.0.0.67
Any suggerences?
Regards
Paco
Humm I am unable to reproduce this. are you using the default database? If so can you send me your database and configuration file in a PM please so I can re produce the error?
Hi - another crash issue.  PlexNotify v.0.67 crashes in the Log of Events window whenever I click on an item on that screen.
Windows Vista64bit operating system, default database for plexNotify
Just tried this and can confirm it happens to me too
Sent from my Nexus 5 using Tapatalk
Hi everyone I apologize for the crashes. I am working to resolve them now. Its associated with the speeding up of loading the video data in the statistics screen. I will have this fixed asap.
No need to apologise, it's an alpha, people should expect a few bugs here and there.
Keep up the great work.
I pushed what hopefully is the fix at the very least added more debugging.
Alpha v0.0.0.68
 - Fixed crash.
 - Made stats page re-sizable.
where's the "speeding up"? I really don't see any improvement when opening statistics (getting data...)
