Plex Notify
where's the "speeding up"? I really don't see any improvement when opening statistics (getting data...)
How many videos is it loading? I can have an option to keep them cached in memory so you dont have to wait every time you open the stats screen.
Alpha v0.0.0.66
 - Fixed memory leak in Stats page *Really this time*
 - Fixed some cases that would cause High CPU Usage.
 - Added a garbage collect button to settings.
 - Improved stats window load time.
High CPU usage is fixed for me, back to business as usual, thanks!
Glad I could help! thanks for the donation!
Can it be possible to make Stat over how many there is connected every hour?
I like to see how many of my users are connected on 0 to 23 (0 AM to 11 PM) possible with a interval every 15 min.
It will be great, so i can use the small times to put movies over on Server.  :) or do other things.
Kindly Me
what do you mean? how many movies/tv shows I have?
When the stats screen is loading theres a bar in the lower left hand corner that twlls you how many its loading
Sent from my SM-N900P using Tapatalk
The "getting data" is 238 right now (if this was the question...)
James, for your information, it is not fixed error jet... In v.0.0.68 version same error.... Show me any pictures from movies, but at 3 or 4 seconds crash again...
Tnks.
Paco
P.D It's possible that error was with statistic value resulted from watched movies?. Only, a comments...
Tnks.
Paco
Thanks for the info, does the log show any information I added extra debugging.
Tnks.
Paco
Nevermind I found the problem =)
Hi James, same problem in Alpha v.0.0.6.9:
Error log:
    0.0.0.69
    Specified element is already the logical child of another element. Disconnect it first.
       en System.Windows.FrameworkElement.ChangeLogicalParent(DependencyObject newParent)
   en System.Windows.FrameworkElement.AddLogicalChild(Object child)
   en System.Windows.Controls.UIElementCollection.AddInternal(UIElement element)
   en System.Windows.Controls.UIElementCollection.Add(UIElement element)
   en PlexNotify.StatsWindow.BW_RunWorkerCompleted(Object sender, RunWorkerCompletedEventArgs e)
P.D: Good job in debug log mode.
Thnks,
Paco
Error log:
0.0.0.69
Thnks,
Paco
Thanks for the info this helps a lot!
I pushed what hopefully is the fix at the very least added more debugging.
Alpha v0.0.0.68
 - Fixed crash.
 - Made stats page re-sizable.
Hi, a minor bug with the stats page when I re-size it:
![post-243790-0-07089900-1399819799.png|690x358](upload://7q0nwTOQxWuzmBJSOP5otTbKKow.png)
Tobias
I pushed 0.70 I think I fixed the video problem some of you are having hopefully. I also Updated the Overview page.
Great view.  B)
JB,
I have a problem when I watch channels and the name is really odd or long. It’ll crash PlexNotify and any future instances of it until I delete the dB.
Sent from my DROID RAZR HD using Tapatalk
JB,
I have a problem when I watch channels and the name is really odd or long. It'll crash PlexNotify and any future instances of it until I delete the dB.
Currently there is a 255 character limit on any title. in the next patch I will up it to 4000.
Thx JB!
Ok, I see no love for my Philips hue integration, so maybe you can expand the plugin documentation a little bit or provide a sample project and i'll implement it by myself
The lightbulb? did you want a light to blink when you got a notification?
The notification plugin interface can be found here: https://plexnotify.codeplex.com/wikipage?title=IPlexNotificaton&referringTitle=Pugin%20Interfaces
