Plex Notify
If it has an api of some sort, you could use eventghost to flicker the light
Sent from my Nexus 7 using Tapatalk
Alpha v0.0.0.71
 - Top Charts added
 - Basic RSS added can be found at http://*ip*:*port*/rss/
 - Webserver added for RSS. No pages yet. *The webserver is disabled by default*
For the love of God, Will you finally give users like me the option to eviserate that obnoxious horizontal loading crap display on the Settings page?
I'd love Hue integration... tying events into start / stop / pause etc would be awesome!
Sorry to ask, but any idea when the web server will be ready for testing?
I would love t implement this but there are a lot of other features that I have to wrap up like email, pushbullet and recently added. this is on my radar but its not high on the priority because its a very nitche thing that only a few users would use.
Look man I appreciate you passion on this matter but as I stated above, there a lot more pressing things that need to get done first. I Cant keep taking time away from these other things to fill small requests. I have a full time job, a wife and a kid. This is only a side project. I have little to no time to work on it some days and I need to work on the features most demanded. once I finish Beta 1 I will add this to the software, for now you will have to deal with the "obnoxious horizontal loading crap" aka the loading bar on the stats screen.
If you feel that passionately about it here is a link to a program with 0 loading bars: https://forums.plex.tv/topic/79616-plexwatch-windows-branch/
ehmmm.... high CPU usage is back on 0.0.0.71... 50% CPU usage all morning. any chance of a download link to 0.0.0.70? Thanks!
It should be on the downlods page. Just turn off automatic updates. And uninstall your current version.
Sent from my SM-N900P using Tapatalk
You are getting this software for free.  Demanding anything from someone doing it as a hobby is just plain rude.
I'm not hitting 50% (10% on a dual xeon processor server) but it's pretty much a constant 10%, it was hitting around 3-4% every so often before.
I have a pretty weedy Dual Core CPU from 2007 on my PMS machine.. I have the log checking frequency reduced a bit and Plex Notify never exceeds more than about 5% CPU (usually in little peaks and troughs). But the 71 release is pegging the CPU at a consistent 49 - 51% all the time; not sure why.
JBurlison I've checked the downloads page on the website but for any older versions it just directs me to the one-click latest version. Yup I think I'll disable auto updates for now!
I will fix it when I get home
Just catching up on the updates, great work.
Really like the new features and filters but I still seem to have high memory usage ranging from 200 (currently 500+Mb) - is this normal? I'm running the latest 0.0.71 build
There is a .net bug that keeps the images in memory and the are not being garbage collected. I have a work around in the process to make the stats screen a separate process.
Cool, thanks for the update... forgot to ask what port number should be input to see the RSS feed?
Its in the settings tab
I must be being a noob but can't seem to get this working, the port in settings suggests 8082 but after entering this in the url along with my manual I.P (or my redirect account) I get nothing! ports have been forwaded in router config...
The only thing you should have to change is the port number not the IP address in that setting. The IP is only to specify a IP address to listen on if you have multiple IP's on your machine.
So it should be something like 8082:localhost I believe.
J, I just wanted to thank you for the effort your putting into this and to tell you not to listen to the jackasses. For every one of them there are twenty of us who appreciate your hard work.
Keep up the good work.
James, wanted to thank you for all of the hard work.  I just installed .71 onto my server and it is actually working!  I am collecting data.  Now, is getting the data I have been collecting all of these weeks that's sitting on my laptop transferable to the server so I don't lose anything?  Is it as simple as shutting down both instances and copying the PlexNotify.sdf file from one machine to the other?  I know that there should be some other things that need to be copied, logs, image_cache, etc.  Do you have a list of everything I should copy?
To refresh I am running 2012R2 Essentials.  I had last tried .61 which is what I am still running on the laptop.
Really appreciate the work you have put into this.
Thanks!
Larry
Just move your config and sdf file and you should be all set. It will rebuild the cache or you can transfer that too
