I still experience crashes as well. Let us know if further logs are needed to pinpoint this issue.
There you go. Note that those settings are not the ones I've got configured daily, I was trying to mess around the settings page and see if I could get it to stop crashing, turning notifications on/off etc. But still crashes with this config.
I think I found the bug.
Hey @JBurlison@Gmail.com
Sorry but im a total newby at this but I keep getting this error?
Im not really sure what are the correct details to enter for the Plex IP/Host name & Plex port,
if you could help me out that would be great,
Cheers
Cheers
Is the plex server running on the same machine?
if so your host should be localhost or 127.0.0.1 and port should just be 32400
hey James I went to send you some money via paypal but for some reason the link within PN takes me to a url that says it's no longer valid (an actual paypal site however) can you give me your info so I can send you some dough. you can pm if you need to.
it should be working, I just tested it. Theres donation link in my signature. Thanks!
Quick question, I'm still on an older version (0.70) because of high CPU usage on my system with later versions.
When I open up the Statistics page I can see messages "Setting Filters" and "Getting Data". I happened to leave this page open earlier when I went to work, and having checked now a couple of hours earlier I see the same messages keep appearing and the CPU has been hammered the last few hours. Nothing is being played these last few hours by any user. Is this expected behaviour? If I close the stats screen CPU goes back to normal and Plex Notify works as normal. Thanks!
I would suggest updating, a lot of the CPU issues have been fixed. you can test it out by installing plex notify on another machine first and pointing it at your plex server to see the CPU use.
Yes I'm running my server on the same machine,
I just changed my Plex IP/Host Name to 127.0.0.1 & my Plex Port is 32400,
so far its still not working, (though when I open Plex Notify got to Plex>Louis>opens IE & loads plex)
Still not showing any stats/user/anything in the program
What is the URL of your server that you use to access it in IE?
In Plex Notify I go to Plex>Louis> opens IE, URL:http://127.0.0.1:32400/web/index.html#!/dashboard
When i open Plex in Media Manger... In the Plex Media Server: URL http://localhost:32400/web/index.html
Are you logged into your server when you visit the page with your plex pass account?
127.0.0.1, 32400 should work fine.
Yeah I'm logged into my plex pass account when I visit the page
Im using 127.0.0.1 & 32400 and still no luck
can you post your log file?
Alpha v0.0.0.98- Fixed Index out of range bug.- Fixed Messages not populating in settings.
Yup. Everything works normally, thx!
Glad to hear!
Here you go man
I see that it cannot connect. Make sure there are no spaces in your IP address or port.
alternitively your configuration should work right out of the box. So delete your config file and re-start plex notify and see if that works.
this reads like you have the host and port in the port textbox.
There are no spaces, this is what ive got,
http://i.imgur.com/SlOd1iQ.png
Ive restarted, hell even re-installed the program, still getting the same problem
How exactly do I delete my config file?
C:\programdata\Plex Notify
Ok I deleted my plexnotifysettings,
restarted plex notify, had to add sign in details, my plex ip/port was the same (127.0.0.1:32400)
still the same problem,
about to flip my dick out on this ■■■■■.
can you go to http://localhost:32400/status/sessions ? does that display anything? thats the page its trying to get to.
