Plex Notify
Someone made this awesome suggestion for Plex Notify https://plexnotify.codeplex.com/discussions/548505#post1255802
can you go to http://localhost:32400/status/sessions ? does that display anything? thats the page its trying to get to.
This is what it says
This XML file does not appear to have any style information associated with it. The document tree is shown below.
I have seen that before.ex my lg tv shows that connecting via the dnla built in.if I use the plex app it shows proper info and plex notify displays it.there a thread somewhere that has a link which shows which clients report session info(think its a link to the support wiki section).so this may not be a bug in plexnotify....
I found the post...
https://forums.plex.tv/topic/111520-plex-clients/
DLNA and people watching via a web browser do not constitute as clients. Plex Notify treats all DLNA plays as the DLNA user.
Sent from my SM-N900P using Tapatalk
Hello all
Plex notity used to be working before these updates, right now I do not get any notification, I uninstalled plex notify and deleted all the folders belong to it, and reinstalled it, and still it does not work. Any advise?
Hello all
Sorry, do you have the latest PMS installed 0.9.9.11?
Yes I do have the lastest PMS, I noticed in basic setting tab I can not select plex server from the drop menu its showing empty drop menu.
I think I might know the problem.
Confirmed. I found the bug. You wont be able to add or edit servers at the moment. Even a fresh install wont save you. I will patch this asap.
Alpha v0.0.0.99
 - Fixed not being able to add new servers.
 - Fixed fresh installs not working.
 - Fixed null object bug.
Alpha v0.0.0.99
Thank you for your quick response to my problem, unfortunately the new update did not fix my issue.
lol I forgot to save the file. I will push the update again.
Alpha v0.0.0.99 - 100
small issue, for PushAlot notifications, I'm trying to disable both client connected and disconnect but it doesn't keep the settings... (when I go back in, it's stuck back enabled)
K just edit the confi directy til i can get another fix out.
You are awesome.
Thank you
Ok I deleted my plexnotifysettings,
restarted plex notify, had to add sign in details, my plex ip/port was the same (127.0.0.1:32400)
still the same problem,
about to flip my dick out on this ■■■■■.
I think the latest patch will fix your problem
I have decided to add a bandwidth, CPU, memory, Hard disk monitor before beta 1 also. I will make settings to set thresholds, This way you can track your system stats over time and send out alerts when a threshold is broken.
Also, I will be starting a paid mobile app upon release of beta 1. It will be available on iPhone, windows phone and Android.
Thanks for the app, it's been a value add. The last two version releases have been causing me issues. The app no longer properly displays correctly on my screen, therefore I can't access any of the items without going the taskbar route to reach settings, plus information no longer populates on the main screen as shown below:
Thanks for the app, it's been a value add. The last two version releases have been causing me issues. The app no longer properly displays correctly on my screen, therefore I can't access any of the items without going the taskbar route to reach settings, plus information no longer populates on the main screen as shown below:sp96oz.jpg
Ahh this is a product of calculations being off because the window is larger then your screen height. I will have a fix next patch.
