Plex Notify
To Intruder71: My mistake  :(
To JBurlison: Thanks for update  :) but i got a crash on startup when i try to go to settings, even after deleting PlexNotify ProgramData, tryed to uninstall it and get at clean PN, now PN crash at first at startup.
    0.0.0.108
    Application started.
    0.0.0.108
    The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log for more detail. (Exception from HRESULT: 0x800736B1)
      at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
   at System.Data.SqlServerCe.UnmanagedLibraryHelper..ctor(String fileName)
   at System.Data.SqlServerCe.NativeMethodsHelper..ctor(String modulePath)
   at System.Data.SqlServerCe.NativeMethods.LoadValidLibrary(String modulePath)
   at System.Data.SqlServerCe.NativeMethods.LoadNativeBinariesFromPrivateFolder(String privateInstall)
   at System.Data.SqlServerCe.NativeMethods.LoadNativeBinaries()
   at System.Data.SqlServerCe.SqlCeEngine..ctor()
   at System.Data.SqlServerCe.SqlCeEngine..ctor(String connectionString)
   at PlexNotify.Databases.MSSqlCE.GetCeConnectionString() in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\Database\MSSqlCE.cs:line 151
   at PlexNotify.Databases.MSSqlCE.Connect() in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\Database\MSSqlCE.cs:line 141
   at PlexNotify.Databases.MSSqlCE.RunReturnQuery(String sql, Dictionary`2 sqlParameters) in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\Database\MSSqlCE.cs:line 98
   at PlexNotify.DatabaseInterface.SetupDatabase() in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\Database\DatabaseInterface.cs:line 41
   at PlexNotify.MainWindow.splashBackgroundWorker_DoWork(Object sender, DoWorkEventArgs e) in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\MainWindow.xaml.cs:line 191
    0.0.0.108
   at PlexNotify.DatabaseHelper.RegisterClientWithDatabase() in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\Database\DatabaseHelper.cs:line 394
   at PlexNotify.MainWindow.splashBackgroundWorker_DoWork(Object sender, DoWorkEventArgs e) in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\MainWindow.xaml.cs:line 216
I pushed an update that can possibly fix this. v109
http://www.plexnotify.com/Releases/Alpha/
With old DB and possiblet clean PN, PN starts up,
"Open" works (i think) but no "Connection Clients" or Notifycations
pressing "Settings" causing Crach
pressing "Statistics" causing Crach
I notice after last update of PMS, they done something with they DB
Sorry to disappoint you JB getteing this
    0.0.0.109
    Possible file version mismatch detected between ADO.NET Provider and native binaries of SQL Server Compact which could result in an incorrect functionality. This could be due to the presence of multiple instances of SQL Server Compact of different versions or due to wrong binaries with same name as SQL Server Compact binaries. Please install SQL Server Compact binaries of matching version.
      at System.Data.SqlServerCe.NativeMethods.IsValidBinary(String filename)
   at System.Data.SqlServerCe.NativeMethods.ValidateNativeBinary(String modulePath)
   at PlexNotify.DatabaseHelper.GetUsers(DatabaseInterface db) in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\Database\DatabaseHelper.cs:line 207
   at PlexNotify.DatabaseHelper.GetUsers() in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\Database\DatabaseHelper.cs:line 197
   at PlexNotify.SettingsWindow..ctor() in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\SettingsWindow.xaml.cs:line 434
I'm getting the same crashes on 109
Sorry James, hate to say it, but now it's crash at startup, with and without old DB
Running at Win 2008 WebServer, 16Gb ram, Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
    0.0.0.110
    0.0.0.110
   at PlexNotify.MainWindow.splashBackgroundWorker_DoWork(Object sender, DoWorkEventArgs e) in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\MainWindow.xaml.cs:line 213
    0.0.0.110
   at PlexNotify.MainWindow.splashBackgroundWorker_DoWork(Object sender, DoWorkEventArgs e) in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\MainWindow.xaml.cs:line 238
Clean Install : Invalid User or Password pops up
Log.....
    0.0.0.110
    0.0.0.110
    0.0.0.110
I wanted to give an update.  I just installed 109 onto my Win7 64 bit laptop that is running the standard database.  I shutdown PN before installation and it installed without any issues.  It then opened without any issues.  I checked settings, showed it is 109.  I was able to get into everything in Settings.  I then checked my Statistics and I can now finally click on the links showing the usage of each video, tv show, etc.  Not seeing any issues, the problems we were all having appear to have been resolved.
James, I have not tried this on the MySQl database I have on my 2012R2 server before I am having an issue with the database!  It stopped working about a week ago after I had to do a server reboot, the database will not come back.  Might just wait for your v1.x version which you said should include a MySQL database and leave well enough alone.  Have enough things to deal with in the house.  lol
Thanks for all of your hard work.
Larry
Have just tested on my Win7 64 bit to and it's works 100%, but not on my Server (Win 2008 Web) :-( Crash
Mine stops for over a month ago :-(
hello
Is that a version with the ability to run external scripts is provided (in the context of use in home automation)
Thank you in advance for your answer.
am I the only one who can't reach the new release? plexnotify.com is offline for me :s
No i can't rearch it to  :(
Its back up. Someone ddos me…
Sent from my SM-N900P using Tapatalk
I was able to download and install the new version now :)
Got this installed for first time yesterday and worked without a hitch!  But when I checked this morning it was no longer running.  I assume it crashed?
Anything I can send to help debug?
if you go to C:\ProgramData\Plex Notify\Logs all logs are there. Just pastbin it or email it to me. I will check it out.
I have time to work on the project again, I am working on Email and a Web UI for the webserver. the web will probably come before the Email.
It starts....
Nice!
Ok web interface looking awesome. Let me know if you need help. I do graphics and web design. Im not good at making functionality but I can make ■■■■ look good. Anyway, I just updated and crashes repeatedly so im using plex watch for the time being. Hoping all gets sorted out. I appreciate all the hard work.
Speaking of which check out plex watch webui if you need ideas. Might be abke to even team up since you guys are doing the same thing.
try renaming your data folder C:\ProgramData\Plex Notify
See if that fixes the crash.
