Ok so oddly enough that is my data folder and even more odd I didn't have to fix change anything it just started working and stopped crashing. So on that part I'm really baffled. My other question is should my installation directory be something crazy like "C:\Users\Administrator\AppData\Local\Apps\2.0\YK3Q3C10.716\C2DYVMBD.XVC\plex..tion_74c4c3a5386d1f89_0000.0000_4456c961a3d1d15b"
Yeah thats where clickonce installs it.
Ok just wantwd to make sure thats normal. I didnt have a choice. I use always up to keep things running. I was gonna keep it running. Used to running the apps from program files. I can dig it though. Thanks for the quick replies. Anything I can do to help in development please let me know.
Sorry to inform you James, but even after a clean install PN crash on a "Windows 2008 64bit" server, have notice that can possible be some updates from MS there do some bad things, for PN have worked 100% before, but thats over a month ago.
BUT under my Win7 64bit Pro, it's working 100% without errors.
Hope you can get to work again under "Windows 2008 64bit" server.
KEEP going for THAT good work.
Log after cleanup of system and trying to install PN again
Same here win 7 (x64) fine
WHS 2011 (x64) was running OK a week ago doesn’t work now…
I am running on wondows server 2008 r2 with no issues currently. It was crashing but magically corrected itself and is now solid. This brings up a valid point though. Perhaps this could be configured to run on a different machine / vm?
I'm running at a Windows 2008 Web Server (the first 2008) / Xeon E3-1230 V2 and don't know to run in wm :-(
What about you config Intruder71 ?
Whs 2011 running native on a Hp proliant
Plex notify in a folder on its on C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
Is anyone else having problems with auto-update not occurring any more.
I read posts by the author some time ago discussing v0.0.0.109, but mine is still v0.0.0.107, so it lags at least two releases behind.
I have terminated and restarted PlexNotify several times since then, and it still hasn’t auto-updated.
Does this match the results of others here ?
Mine is running on a Win7pro_x64 system, together with the PMS server.
Both PMS and PlexNotify work fine, I just wonder why the latter won’t update.
Best regards: dlanor
I have another problem with my username, it has a space in it. On some devices it is displayed properly others process it with a plus between them. for example "Solar Bang" and "Solar+Bang"
I have included an image to explain. I was wondering if i could group them or merge them together. I'm thinking the same for DLNA since it's always usually just me using it a the house.
I have terminated and restarted PlexNotify several times since then, and it still hasn't auto-updated.
Both PMS and PlexNotify work fine, I just wonder why the latter won't update.
I had to move where I host plex notify to one of my personal servers. For the new version this time you will have to update manually. Just go to www.PlexNotify.com
Sent from my SM-N900P using Tapatalk
I will add this to the feature list.
For those getting the database errors. Please download and install this. http://www.microsoft.com/en-us/download/details.aspx?id=17876
Thanks, I really appreciate it. Im sure this might help some other people too incase they want to figure out what content to sync for a device shared between 2 parties (parents) or people like me with spaces in their name. Have you put any more thought into separate notifications for users (public) and admin (private) to be able to customize multiple feeds. The other idea which isnt necessary because somone could manually email a report, but it might be cool to be able to send somone a usage history of themselves (shared login) or another user (children) to keep an eye on their kids. Im mainly interested in the first idea for cutomized private vs public feeds because I want my users to be able to see new additions without having to worry about them seeing everyones viewing habits. Not trying to make more work for you, just ideas to make the product better. Thank you again for all that you do and addressing username issue.
THANKS James, that solved my PN problem on my server, works 100% again with my old DB... :D
again
THANKS James, that solved my PN problem on my server, works 100% again with my old DB... :lol:
Love this app, thanks for all the work on it!
Thanks. I've now installed v0.0.0.111 as linked at that address.I had to move where I host plex notify to one of my personal servers. For the new version this time you will have to update manually. Just go to www.PlexNotify.com
James, your site is down.
Uh-oh, something went wrong! Error Code: 503
When I change the date in Filter Options on Stats it doesnt seem to stick. Still showing last months stats. Am I doing something wrong?
Having issues with the "Recently Added" notifications - in that they don't seem to happen. The new shows/movies I add show up in plex, but the notifier doesnt seem to catch them at all or even show up in the log. I have the basic notification and pushover notifications enabled for recents. Is there anything I need to do?
Thanks!
