Hi
Thanks again.
But I may have missed something.
Ho do you do a non Primary install?
I have an install on a server with a SQL database.
And it runs fine there.
But I want to install this on my personal machine too.
And use that to browse watched and notifications.
But how ever I try to install. I can't set is as a non primary.
Is there an other installation for non primary?
Cheers
Jammy_B
October 23, 2014, 7:09pm
1722
Can you shufty the "most concurrent streams" a bit more to the left please?
I can't see the total regardless of how I shape/reshape the window when RDP'ed on iPad :D
???? Just needs moving over a bit please!!
Any word on a Mac OS release? This looks amazing
Just installed the xbox 360 app and the Pushalot notification shows me a long guid rather than a device name. As the app doesn’t allow configuration of a device name I suspect this is why. Anyone else seeing this?
What version are you running?
Sent from my SM-N900P using Tapatalk
0.0.0.107
windows 7 64 bit and all updates installed including security patches
This didn't happen before with the previous notify version until I updated it.
out of curiosity... will we be able to configure certain events not to push notifications (i.e. trailers) with the new rebuild?
Regards
Tylor
Regards
Tylor
yes.
sorry no mac release.
The next version will have a new UI and it will MUCH faster.
Also, Next weekend I will be releasing the service with the following API's:
Plugin (C#)
HTTP GET (web api)
Websocket - (web api) - For push notifications.
TCP socket - For push notifications.
The service will be a windows service. or it can be executed via a command prompt with the -debug command for developers.
After a fresh install, i am just getting error: "Invalid username and password"
And then the program crashes.
Havent got the chance to write in username and password yet.
Any fix for this?
Any fix for this?
The settings file is in c:\programdata\plex notify
Should these be replaced with my username and password?
EDIT: or this one?
Server=127.0.0.1/PlexNotify;Database=PlexNotify;User Id=sa;Password=plex;
Replacing sa and plex?
EDIT: or this one?
yep replace the lines with:
myUser
myPass
myUser
myPass
Not getting wrong password and username anymore.
Now the program just crashes instantly, after reaching "Finalizing"
try deleting the plex notify folder.
After deleting C:\ProgramData\Plex Notify - i get same crash
is anyone watching anything on your plex server? if you go to
http://yourplexip:32400/status/sessions
is there a bunch of XML there? or only 1 line?
There is a bunch of XML there. Yes
Can you send it to me?
Sent from my Nexus 9 using Tapatalk
Here on this forum?
no sensitive information in it?
Here on this forum?
You can email it to me. It only has media metadata in it and Plex usernames. Also send me the logs.
Sending it now to your email:
<span><a class="" href="https://forums.plex.tv/user/64511-jburlisongmailcom/" title="">JBurlison@Gmail.com</a></span>
