Plex Notify
On my Windows 8.1 system, I cannot seem to run the program from the start menu or after a reboot. The program is in the taskbar, but if I right mouse click and select items, I receive a PlexNotify has stopped working error message.
I am only able to get it to work if I go into the directory like "C:\users\username\AppData\Local\Apps\2.0\XXXXXXXXXXXXXXXX\plex...tion_XXXXXXXXX" and select the program to run as administrator from that location (doing from the start menu or selecting it to always run as admin in the properties does not work
Is anyone else encountering this issue?
Hey,
I really do love this app when it was working, seems like some folks got it working with the most recent version. I'm still having some issues and the error log is below. Can someone advise? Thanks!
PLATFORM VERSION INFO
Windows : 6.1.7601.65536 (Win32NT)
Common Language Runtime : 4.0.30319.18444
System.Deployment.dll : 4.0.30319.18408 built by: FX451RTMGREL
clr.dll : 4.0.30319.18444 built by: FX451RTMGDR
dfdll.dll : 4.0.30319.18408 built by: FX451RTMGREL
dfshim.dll : 4.0.41209.0 (Main.041209-0000)
SOURCES
Server : Microsoft-IIS/7.5
X-Powered-By : ASP.NET
IDENTITIES
Deployment Identity : Plex Notify.application, Version=0.0.0.111, Culture=neutral, PublicKeyToken=74c4c3a5386d1f89, processorArchitecture=msil
Application Identity : Plex Notify.exe, Version=0.0.0.111, Culture=neutral, PublicKeyToken=74c4c3a5386d1f89, processorArchitecture=msil, type=win32
APPLICATION SUMMARY
* Installable application.
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of http://www.plexnotify.com/Releases/Alpha/Plex%20Notify.application resulted in exception. Following failure messages were detected:
+ Value does not fall within the expected range.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [10/3/2014 9:54:34 AM] : Activation of http://www.plexnotify.com/Releases/Alpha/Plex%20Notify.application has started.
* [10/3/2014 9:54:34 AM] : Processing of deployment manifest has successfully completed.
* [10/3/2014 9:54:34 AM] : Installation of the application has started.
* [10/3/2014 9:54:35 AM] : Processing of application manifest has successfully completed.
* [10/3/2014 9:54:35 AM] : Found compatible runtime version 4.0.30319.
* [10/3/2014 9:54:35 AM] : Request of trust and detection of platform is complete.
ERROR DETAILS
Following errors were detected during this operation.
* [10/3/2014 9:54:35 AM] System.ArgumentException
- Value does not fall within the expected range.
- Source: System.Deployment
- Stack trace:
at System.Deployment.Internal.Isolation.IStore.LockApplicationPath(UInt32 Flags, IDefinitionAppId ApId, IntPtr& Cookie)
at System.Deployment.Application.ComponentStore.LockApplicationPath(DefinitionAppId definitionAppId)
at System.Deployment.Application.SubscriptionStore.LockApplicationPath(DefinitionAppId definitionAppId)
at System.Deployment.Application.FileDownloader.PatchFiles(SubscriptionState subState)
at System.Deployment.Application.FileDownloader.Download(SubscriptionState subState)
at System.Deployment.Application.DownloadManager.DownloadDependencies(SubscriptionState subState, AssemblyManifest deployManifest, AssemblyManifest appManifest, Uri sourceUriBase, String targetDirectory, String group, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
Hey all!
The December target of the new Plex Notify is on track! This will be an entirely new version of Plex Notify. New Installer, new UI, new Plex Notify Service!
I almost have the Rest API interface done so if anyone has any Web programming experience it would be great to get help on the web UI. I started one and it is a lot for me to learn at the moment. I am sure someone with much more Web programming experience will do a much better job on the Web UI than I ever could.
So if you are a web developer and are willing to help by writin a web UI that is compatible with both Mobile and Desktop I sure could use it!
Nevermind :)
Nice program. It works pretty well to.
I have one question/problem.
I have managed to set it up on a Windows server 2012 with a SQL Ex database.
And I added two plex servers.
But It only grabs info from one of them.
Any ideas?
Cheers
EDIT:
I'll just go to bed now..
I just forgot to login to myplex...
All good now..
Let me know if you need a place to hold files. (like a mirror)
I have 100/100 line now. and Just waiting for my ISP to upgrade the central :) Then I'll prob have 1000/1000 ^^
Cheers
First of all, love the program and it works well for me. I do however have one small request. I use PushBullet to let me know what people are doing when I'm not near the machine and sometimes I have a few lined up when I next check. Is it possible to add a {CurrentTime} to insert current time into the message? I tried the {EndTime} as a work around but of course if the person doesn't get to 100% it doesn't work how I want.
Cheers.
Hey all!
Excellent !
What do you think of this idea ?
- Device limit per user account on Multi-User features -
if you get the page set up for mobile and desktop I could help style it. I do web design and graphics design. I have made many web pages before and in recent time developed for both mobile and desktop,but the majority of my experience is desktop. So I don't want to volunteer and disappoint here. That being said if someone is trying to help crank it out, I can definitely style it up or provide some graphics, textures, buttons. Favicons, etc.
If I use this code for DateTime format:
dd/MM/yyyy hh:mm:SS
it doesnt show as 24 hour clock.
Example: 00:00:00 is shown as 24:00:00
How can i change this ?
dd/MM/yyyy hh:mm:SS
dd/MM/yyyy HH:mm:SS
Cheers.
I will add this to the list thanks!
Still crashes when I click on a user under statistics. Any idea how to fix this?
What version are you running?
Sent from my SM-N900P using Tapatalk
I just installed Plex Notify, but it crashes soon after starting.
It will display a balloon telling me my username and pass are not right, well I did not configured the app yet, so yes that's correct.
Then a popup shows up stating that Plex Notify stopped working.
I installed it in my Windows 2008 server.
I hope you have a solution for me.
Regards,
Regards,
Plex web has been down all day.  I'd try it again later.
hello
desolated for my english
I just installed plex notify works very well
but it does not show me the ip of users connected
there is something he has set you
thank you in advance for your answers
Re-installed today and still nothing.
I see this in the log file:
    0.0.0.111
    The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log for more detail. (Exception from HRESULT: 0x800736B1)
any ideas?
    0.0.0.111
any ideas?
Make sure you have .net 4.5
The setup installed it.
The stopped working pop-up give me this deatils
Description:
  Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: plex notify.exe
Problem Signature 02: 1.0.0.0
Problem Signature 03: 54278343
Problem Signature 04: System.Data.SqlServerCe
Problem Signature 05: 4.0.8876.1
Problem Signature 06: 4fcd17f1
Problem Signature 07: 401
Problem Signature 08: 17
Problem Signature 09: System.Data.SqlServerCe.SqlCe
OS Version: 6.0.6001.2.1.0.272.7
Locale ID: 1043
Also, can it be a problem that Plex Notify is installed on a web server running xampp?
It's the only server next to my freeNas system that runs 24/7
If you need more log's let me know.
Had to revert back to the older version. For some reason the newer version won't open at all.
