EDIT Update. after spending countless hours on this yesterday I just went in to plex on the firestick and its all there . WTF Arggggh .
Can anyone tell me how to remove a server from an Amazon Firestick server list.
I have tried the Plex/TV/Link process numerous times and it just tells me the server is unavailable despite the same process working without problems on my TV’s and Apple TV box.
I have 2 stick’s and it is exactly the same for both. I factory reset one and that didn’t make any difference.
Some users reported they had to clear some kind of cache in the settings of the stick.
one thing I suspect it is is that the server that is showing as unavailable is what was there prior to me tacking action with regards the change of password. That one still retains the old log in details rather than the updated ones post change of PW
Have you switched the left side bar into MORE… mode?
Does it show only one server or two of them?
If the latter, it could be the old and the new one. In which case you probably have to un-pin all the libraries of the old server and pin the libraries of the new one.
Only the one
In more i can see other servers that have been shared with me and they work wine.
