Server Version#: 4.12.3
Player Version#: 8.19.4.26517 (f35a541c)
My player device is a Amazon Fire HD10 android tablet. I’ve installed Plex from the Amazon app store and activated it.
My music library is over 5000 songs, almost all of them have album art. My server is a Synology NAS.
With the app open (on the “home” page), I can open the sidebar to select my library. The library loads on the “recommended” screen. If I tap the “library” icon next to the “recommended” Icon, then the app crashes immediately.
Below is the stacktrace from the logs when it crashes (along with the following startup logs. Thanks so much for your help!
Matt
07-09 08:35:27.526 i: [UserAction] Open change layout dialog.
07-09 08:35:30.510 i: [PlaybackTimeBehaviour] Time: 9994 IsStarted: true
07-09 08:35:30.513 i: Fetching [method:GET] http://192.168.0.25:32400/:/timeline?bufferedTime=181841&duration=298000&guid=mbid%3A%2F%2Fb21c03b5-465b-4907-8adc-d7dccf08e773&key=%2Flibrary%2Fmetadata%2F259&playbackTime=9995&playQueueItemID=210&ratingKey=259&state=playing&time=10158&X-Plex-Client-Identifier=ae45a758ae86e6f1-com-plexapp-android&X-Plex-Language=en-us
07-09 08:35:30.735 e: Fatal exception occurred.
07-09 08:35:30.738 e: An exception occurred: java.lang.NoSuchMethodError: No virtual method setForeground(Landroid/graphics/drawable/Drawable;)V in class Landroid/widget/RelativeLayout; or its super classes (declaration of ‘android.widget.RelativeLayout’ appears in /system/framework/framework.jar:classes2.dex)
07-09 08:35:30.767 e: Stacktrace: java.lang.NoSuchMethodError: No virtual method setForeground(Landroid/graphics/drawable/Drawable;)V in class Landroid/widget/RelativeLayout; or its super classes (declaration of ‘android.widget.RelativeLayout’ appears in /system/framework/framework.jar:classes2.dex)
at com.plexapp.plex.utilities.ListItemView.setPlexObjectImpl(SourceFile:10)
at com.plexapp.plex.utilities.d2.setPlexObject(SourceFile:6)
at com.plexapp.plex.adapters.q0.g.X(SourceFile:16)
at com.plexapp.plex.adapters.q0.i.X(SourceFile:1)
at com.plexapp.plex.adapters.q0.i.onBindViewHolder(SourceFile:1)
at androidx.recyclerview.widget.RecyclerView$Adapter.onBindViewHolder(SourceFile:1)
at androidx.recyclerview.widget.RecyclerView$Adapter.bindViewHolder(SourceFile:8)
at androidx.recyclerview.widget.RecyclerView$Recycler.tryBindViewHolderByDeadline(SourceFile:7)
at androidx.recyclerview.widget.RecyclerView$Recycler.tryGetViewHolderForPositionByDeadline(SourceFile:55)
at androidx.recyclerview.widget.RecyclerView$Recycler.getViewForPosition(SourceFile:2)
at androidx.recyclerview.widget.RecyclerView$Recycler.getViewForPosition(SourceFile:1)
at androidx.recyclerview.widget.LinearLayoutManager$LayoutState.next(SourceFile:3)
at androidx.recyclerview.widget.GridLayoutManager.layoutChunk(SourceFile:12)
at androidx.recyclerview.widget.LinearLayoutManager.fill(SourceFile:9)
at androidx.recyclerview.widget.LinearLayoutManager.onLayoutChildren(SourceFile:65)
at androidx.recyclerview.widget.GridLayoutManager.onLayoutChildren(SourceFile:3)
at androidx.recyclerview.widget.RecyclerView.dispatchLayoutStep2(SourceFile:12)
at androidx.recyclerview.widget.RecyclerView.dispatchLayout(SourceFile:15)
at androidx.recyclerview.widget.RecyclerView.onLayout(SourceFile:2)
at android.view.View.layout(View.java:16076)
at android.view.ViewGroup.layout(ViewGroup.java:5051)
at androidx.swiperefreshlayout.widget.SwipeRefreshLayout.onLayout(SourceFile:11)
at android.widget.FrameLayout.layoutChildren(FrameLayout.java:579)
at android.widget.FrameLayout.onLayout(FrameLayout.java:514)
at androidx.constraintlayout.widget.ConstraintLayout.onLayout(SourceFile:12)
at androidx.coordinatorlayout.widget.CoordinatorLayout.layoutChild(SourceFile:18)
at androidx.coordinatorlayout.widget.CoordinatorLayout.onLayoutChild(SourceFile:7)
at androidx.coordinatorlayout.widget.CoordinatorLayout.onLayout(SourceFile:8)
at android.widget.LinearLayout.setChildFrame(LinearLayout.java:1703)
at android.widget.LinearLayout.layoutVertical(LinearLayout.java:1557)
at android.widget.LinearLayout.onLayout(LinearLayout.java:1466)
at androidx.drawerlayout.widget.DrawerLayout.onLayout(SourceFile:10)
at android.view.ViewRootImpl.performLayout(ViewRootImpl.java:2122)
at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:1879)
at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1090)
at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:5988)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:781)
at android.view.Choreographer.doCallbacks(Choreographer.java:592)
at android.view.Choreographer.doFrame(Choreographer.java:560)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:767)
at android.os.Handler.handleCallback(Handler.java:739)
at android.os.Handler.dispatchMessage(Handler.java:95)
at android.os.Looper.loop(Looper.java:135)
at android.app.ActivityThread.main(ActivityThread.java:5597)
at java.lang.reflect.Method.invoke(Native Method)
at java.lang.reflect.Method.invoke(Method.java:372)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:984)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:779)
07-09 08:35:36.843 i: [AppEventMonitor] ApplicationCreated
07-09 08:35:37.053 i: ------------------------------
07-09 08:35:37.054 i: Hello, Plex for Android world (debug: false)!
07-09 08:35:37.055 i: App version: 8.19.4.26517 (825653592)
07-09 08:35:37.056 i: Nano server version: null
07-09 08:35:37.058 i: Manufacturer: Amazon Device: suez Model: KFSUWI Product: suez Version: 5.1.1
07-09 08:35:37.061 i: Screen size: XLarge Screen density: High Resolution: 1920x1200 DPI: 240 Touchscreen: true Marketplace: com.amazon.venezia Architecture: armeabi-v7a
07-09 08:35:37.084 i: [BootBehaviour][Background] Network behaviour took 0ms to execute on the background thread.
07-09 08:35:37.100 i: [MetricsSender] Metrics host is not available so we need to fetch the privacy map.
07-09 08:35:37.104 i: [BootBehaviour][Background] Players Manager behaviour took 4ms to execute on the background thread.
07-09 08:35:37.105 i: [BootBehaviour][Background] Metrics behaviour took 20ms to execute on the background thread.
07-09 08:35:37.107 w: [InstallReferrerManager] Unable to read install referrer response at this point. Probably a transient problem. ResponseCode 2
07-09 08:35:37.108 i: [BootBehaviour][Background] Install Referrer behaviour took 6ms to execute on the background thread.
07-09 08:35:37.126 i: [AppEventMonitor] StartingNano +0.29s
07-09 08:35:37.134 i: [Sync] Setting environment variables.
07-09 08:35:37.135 i: [Sync] PLEX_MEDIA_SERVER_HOME = /data/data/com.plexapp.android
