Plex on Ouya
Does the recently released Version of the Android App run on ouya? If so, is it fully supported or is there anything that wont be usable (myplex, plexsync etc)
I installed the PlexPass version over the weekend and while I haven't tried plexsync yet it does show up as a function. I'm using MyPlex with it just fine also. I believe the currently released version is the same as what I installed over the weekend.
Can we get the apk without the plex pass?
yes you can, it is available in the Google Play store.
It is the same versiion as the plexpass version the only difference is that plexsync is disabled.
I get that, just meant to download the apk to sideload on the Ouya without having to rip it from my phone.
You dont need to sideload it because it is already in the Ouya store
http://www.ouya.tv/discover/
BTW does the ouya plex Combo Support hdmi CEC?
Am I missing something, because it is nowhere on that site.
edit: Oh, are you talking about eventually?  Because I am talking about today.
And I downloaded this apk to my ouya, but it still says I need plex pass.  http://forums.plexapp.com/index.php/topic/60585-plex-for-android-kepler/?p=400455
Decided this wasn't worth the effort, got the plexpass to try this now.
Using it on the Ouya is pretty cool, but hopefully the actual release fixes some issues.  Let alone being able to launch it without going into the settings.
It looks like you were one day too soon to the thread you linked to. Try this post
switched from the samsung plex plugin to the ouya tonight. I'm using the same wired (powerline) connection but  I'm having A/V sync issues and bad pixalation and blockyness.
Anyone else?
Did you try adjusting your quality settings?
wished the ios app would support remote-controlling the ouya as i don’t need the controllers then
