Plex on Ugreenn 8800 plus nas
Hi guys.
Could do with a little help please.
I have set up Plex on my 8800 plus Ugreen nas as follows.
Storage pool 1 is 8 x 18tb drives ( for media)
And 1 x 2tb Samsung 990 pro m.2 set up as a normal drive storage pool 2
I have installed Plex container onto the Samsung 990 pro through you tube guide and folders show up in my account but before i dump 66TB from m old Qnap to the Ugreen i think i have done something wrong.
During set up of the container it just pre selected the folder destination that i wanted /tvshows /movies /config folders on the m.2 storage pool.
Should they not go on storage pool 1 main drives media.
I just want to run Plex and meta data from storage pool 2 Samsung pro drive for speed.
I dont want to delete eveything .
Is there a quick work around so Plex container on storage pool 2 sees the folders/media in storage pool 1 please.
Any help would be appreciated.
New to Linux/containers ..Windows was so easy.
Michael
You should be able to change these container paths to whatever host path you want.
IMO you should have the paths mapped like this
  • /config > m.2 pool - /config shared folder
  • /transcode > m.2 pool - /transcode shared folder
  • /media > storage pool - /media shared folder
The storage pool/shared folder would need to be created first before you can update the mapping paths.
