Where is my Plex Config and Meta Data store - TrueNAS
Server Version#: App Version: 1.41.1.9057
TrueNAS SCALE: Dragonfish-24.04.1
Hi all…
Originally had Plex as a TrueCharts deployment, and then recently with ixSystems dropping TrueCharts I moved back onto ixSystems supplied Plex container.
That basically ended as a new container deployment with me pointing it back to my media… and then rebuilding the meta data.
At the moment I can see:
/mnt/bunker/plex/Library
/mnt/bunker/media/
/mnt/bunker/media/Library
I’ve attached 2 screen shots of my storage config as per the container.
Please advise which is real/current and which is a old/mistake…
Need to do some clean up as I’m looking at migrating my entire dataset of /mnt/bunker → /mnt/tank as I need to remove the bunker Diskpool.
G
Interesting enough…
If I open terminal into my Plex container… I only see the /mnt/bunker/media being mounted to /data.
I don’t see /mnt/bunker/plex/Library being mounted inside the container.
G
seems to be the Library sub dir of my /mnt/bunker/media which is mounted to /data
the 2nd /mnt/bunker/plex/Library is old, vs the /data/Library which has a update date stamp of this morning.
G
